LG 42LB1DRA 42 in. LCD Television Logo
A
Anonymous Posted on Jun 25, 2014
Technica lcd 32-270 picture but no sound - LG 42LB1DRA 42 in. LCD Television
2answers
Audio-Technica AT-LP120 turntable. I have crackling in the passive speaker, but when I reverse the speaker wire,ie, red in black & black in red, the crackle appears in the powered speaker.
If you have replaced the cartridge then it must be the cartridge pre-amp that is faulty. If there are any other functions on the device such as CD, then it will not effect them. Unless there is crackling on any other function then the pre-amp has a problem. The pre-amp itself is generally a single IC. You can find it by following the turntable connection back to the inside of the amp. The signals will pass through the IC before being passed to the main pre-amp.
My technica 32 inch lcd keeps turning its self off & on
sounds like one of the transformers is bad which will shut the set down. I need the model number in order to assist you further,
1helpful
I just recently got a pair of Audio-Technica ATH-ANC27 headphones and I've noticed that when I touch the detachable cable the sound shorts out and plays through one side of the headphones.
There is a wire in the detachable cable that is broken inside so might have to cut and rejoin the broken part.Thats why when you touch the detachable cable you happen to move the wire so sound is only transmitted to one ear phone only.
Thanks and good luck
G.
Why is my 32" Technica
Hi:
This is probably due to poor power from the power supply, usully bad capacitors that filter the DC power to the inverters board. The inverter is responsible for lighting the back lamps. Also check the inverter for buldging capacitors as well as the capacitors on the power supply.
I have an Audio-Technica turntable (AT-PL50). I recently moved and when I hooked my turntable back up, the sound is terrible. It sounds distorted, similar to the sound of blown-out speakers. But, I checked...
it sounds like your cartridge is shot and damaged.
this turntable has fixed cartridge and only the stylus can be changed.
check out this manual: http://www.audio-technica.com/cms/resource_library/literature/0fb01429606842cf/at_pl50_om.pdf
1helpful
Lost sound in the right ear of my audio technica ath-d40fs
The most common problem with earphones are the wires. Usually near the end. You can carefully open the headset to expose the wire connection, and check for continuity.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
