Programme is finished door won't open. Checked coin trap and tried manual override to no a ail
SOURCE: open coin trap
use side of spanner to open the circular water drain plug on coin trap, remove all water.
use flat screwdriver to lift yellow tab at top of coin trap whiloe turning coin trap anticlockwise.
SOURCE: I start the machine, it runs till it would appear
disconnect machine from mains electric supply. remove top cover of machine then check the back of the control panel for a small black pipe, it should be attached to a small nipple in the panel rear if it is not you will get the fault you describe. if the pipe is connected remove it and blow down pipe with your mouth or a foot pump to remove any blockage then reconnect it and try the machine again. check also that the pipe is not trapped or kinked too i hope this helps you
SOURCE: dyson cr01 display said clean
check your outflow to make sure there is nothing inside it that can act as a blockage before the coin trap
SOURCE: a buckle or some kind
Sorry to hear you're having difficulties with your Dyson Contrarotator. It's probably best if you get in touch with us directly, so one of our experts can run through some troubleshooting over the phone, and provide the information and assistance you need. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
SOURCE: my machine unable to complete program its saying
To find your coin trap:Loot at the front of the machine, and at the bottom-left is the coin trap.Put towels in front of the machine to mop up any water (it's going to get wet).It opens anti-clockwise (remember righty-tightie, leftie-loosey), but you need to move the little bit of yellow plastic (12-oclock position) up first. The machine dose come with a little tool to do this, but you may have lost it. You can move the bit of plastic up by carefully using a flat screwdriver, and turning the round plastic with your other hand. Don't force anything. After you remove it, just swim over to your machine and remove the yellow thing in the middle by pulling it gently towards you. Clean out the coins/paperclips/buttons that you find in there.Push back on the yellow bit into the coin tray, tighten back on the cover the coin tray (the yellow thing at the top will 'click' back).Using a mop, take the opportunity to clean the kitchen floor now that it is all wet.
