Will not start at all,starter works,power to everything but key ignition
SOURCE: can't remove key from ignition 2001 gmc jimmy
I dont know how much help this will be, but I'll offer it and let you be the judge.
Ive had this issue before in a different GM vehicle, a Pontiac Grand Prix. The issue turned out to be that the voltage from the battery was low due to corroded terminals. Once that was cleaned up and the voltage restored to normal, the key came out. Come to find out that this was a common issue in that vehicle, voltage goes low, you cant remove the key.
Now, on my vehicle and since yours is a GM product as well I will assume it will hold true for your vehicle too, there is a small hole on the bottom side of the column right in the area of where the ignition key cylinder is. If you have this, you can take a small tool like an allen wrench and push it up in there and that will press on a release mechanism that should allow you to turn the key back to its release position and pull the key out.
Hope this helps.
SOURCE: key stuck in the ignition of 1998 GMC Jimmy
sounds like your shift lever for trans isnt making a tight connection when you put it in park....try shifting it in and out of park several times while trying to remove key......my lincoln does that occasionally and when i take it out of park and then back in it works......just a thought
SOURCE: how do i bypass security on 98 gmc jimmy 4.3
Hi: Sounds to me like you tried to start the vehicle with something disconnected in the security system. If this is the case the solution is simple. Put key in ignition and turn to the on position, leave on for EXACTLY 30 minutes... then take key out, wait 5 minutes then start vehicle. Hope this helps... please rate suggestion... ty
SOURCE: 2002 GMC Envoy, i put the key in ignition and
Ignition switch and neutral safety switch. Next time it happens wiggle thekeys in the ignition switch and try to restart.If it starts its probably the ignition switch. Then locate neutral safety switch on brake pedal and put meter on B+ wire from switch to starter relay and see if you get B+ on the would -be- crank. Next locate B+ wire from starter relay to starter hook a meter to it and see if you get B+ on the would -be crank.
Where ever B+ is missing is your problem.
