Question about Tag Heuer Link Automatic Chronometer WJF5112.BA0570 Wrist Watch
Tag heuer second timer not resetting - Tag Heuer Link Automatic Chronometer WJF5112.BA0570 Wrist Watch
5 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: I can't seem to set the time on my used tag heuer watch
Probably your watch has a screwdown crown and prior to attempt any settings you have to unscrew it. Some peoples fingers are stronger then others, so, try that with a pair of plyers. Cover your crown with a soft cloth and then grip with plyers(this will avoid any damage). Thread is right handed and unscrewing is done by turning the crown anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS If the watch is rusty, you can brake the crown off while trying to unscrew it. Don't panic yet, as in this case you will need a watchmaker anyway.
Don't forget to rate, please.
Posted on Jan 10, 2009
Anonymous
SOURCE: Tag Heuer CA 1211-RO Min. Hand resets to 59 Min.
Unscrew the crown and pull out halfway. Use the stopwatch buttons to advance the hand to where you want it. Then push the crown back in and screw it down. You may need to pull the crown out all the way--I cannot recall which setting controls the minute hand and which the hour hand on the stopwatch function. This has to be done every time the battery is changed.
Posted on Feb 05, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: My tag heuer aquaracer has a problem: the second
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4-5 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
Posted on Mar 11, 2009
Anonymous
SOURCE: Tag Timer Resets to Wrong Time
Unscrew the crown and press the lower button, this should advance the minute counting hand one press ata time. Pull ot the crown a further stop to advance the seconds hand and again to advance the tenths counter.
Posted on Jun 08, 2009
Anonymous
  • 22 Answers
SOURCE: my tag heuer carrera stop watch doesnt reset
Try this.
Pull the winder out fully. Then press the top right chronograph button to move the centre seconds hand on. Then push the winder back in.
on some models you should only pull the winder half way out.
good luck
Posted on Sep 23, 2010
How to synchronize Tag Heuer CAN1011.BA0821?
Unscrew the crown, start the stop watch on the time signal. Stop the second hand at 12 o'clock and reset the time (taking out the back lash on the minute hand) Start the watch as the stop watch second hand hits 12. Screw down the crown. Done.
Aug 05, 2014 | Tag Heuer Aquaracer Watches
Instruction manual
If the second is ticking as normally it is not the battery. If the battery is low the second hand will advance only at 5 second intervals meaning for four seconds the second does not move and on the 5th second it will advance by five seconds. This is a feature unique to Tag Heuer.
Nov 18, 2013 | Tag Heuer Link Watches
My tag heuer carrera stop watch doesnt reset properly, when u reset the stopwatch it goes one minute behind and doesnt reset to zero. how do i fix this. it never resets to zero and the red hands on the sub...
Try this.
good luck
Sep 23, 2010 | Tag Heuer Carrera Tachymetre CV2013.FC6206...
I have a Tag Heuer Monaco watch. I has 2
The small seconds hand do not stop because it has nothing to do with chronometer. It is ordinary seconds counter and will move independent of chronometer.Click on my profile (escapement), then click on Tips and Tricks. There you will find link to Tag Heuer watch manuals. It might lelp you. Rate me, please
Mar 31, 2010 | Tag Heuer Link Automatic Chronometer...
I reset the date and now the second hand ticks at
This is END OF BATTERY LIFE warning. Replace the battery and everything will be fine. Rate me plz.
Mar 04, 2010 | Tag Heuer Watches
Tag link - second hand issue
http://ww2.tagheuer.com/_documents/manuals/EI2241_en.pdf
The battery is running down - this is the Tag Heuer early warning system for low battery.
See web page above which is from the Tag Heuer site.
Oct 16, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Tag Heuer Link, stopwatch seconds hand stops 2 seconds before 12
Pull crown out to position 2 [in between unscrewed (1) and pulled all the way out (3)].  Tap Button B (bottom) to reset by step back to zero.
Incidentally, Button A works Hours register in same manner for position 2.  You can similarly reset second and 1/10th with Buttons A and B, respectively, while in position 3.  Cheers!
Jul 25, 2008 | Tag Heuer Link Automatic Chronometer...
Nov 04, 2007 | Tag Heuer Watches
Tag Heuer Link Automatic Chronometer WJF5112.BA0570 Wrist Watch Logo
74 people viewed this question
Top Tag Heuer Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
