Question about Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out, Center Discharge, 240V, w/Hair & Lint Pot
Sta rite pro jet 3/4 hp seems to be frozen..turn on and it hums then quits ..no water pressure
Jason Dinscore
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
It sounds like you have a bad starting compositor. If your compositor is a black plastic one look next to the spade connectors in the cap and you'll see a little resest hole with a brown stopper in it. If that stopper is black, burnt or leaking oil it is bad. If you have a metal one you can set it on it's base on a flat surface. If it rocks it is bad. If the compositor is good you may have a problem with the windings and either need to replace the motor or have it rebuilt.
http://www.austinpooolspecialist.com/
Posted on Feb 25, 2015
5 Related Answers
David Lowry
  • 59 Answers
SOURCE: Spa Motor Hums
if it is a used pump, these have a tendency to have a little rust. just get some pump pliers and rock the shaft gently back and forth. then plug it back in.
David
Posted on May 25, 2009
MOTORWIZJ
Jay Finke
  • 1389 Answers
SOURCE: To purplewg re my Sta-Rite pool pump: I haven't
SOUNDS LIKE BEARINGS .. SEARCH YOUR LOCAL AREA FOR POOL PUMP MOTOR REPAIR GUY, SEE IF THEY OFFER FREE TESTING REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Posted on Jun 30, 2010
MOTORWIZJ
Jay Finke
  • 1389 Answers
SOURCE: I have a Sta-Rite Dura Glas 3/4 HP that when
most of the time its the start capacitor or a dirty start switch. the start switch can be cleaned with the striker off a match book use CARE not to bend the switch , the switch is in contact when motor is starting and open when running... look for free pool pump motor testing in you area and see if they can test the cap for ya as it requires a special meter to do THE TEST RIGHT ! and you might need a shaft seal when all is done. good luck// jay the pool pump repair guy FLORIDA
Posted on Sep 30, 2010
john224
John Prohaska
  • 1378 Answers
SOURCE: My sta-rite pump makes a
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Oct 05, 2010
Dale Cobb
  • 366 Answers
SOURCE: pump was running until turn
either debris in pump causing impeller to hang, or you need a start capacitor.
Posted on Aug 14, 2011
Sta rite dyna glas 1 hp pool pump low water pressure
There are a few questions you need to address first. One is the pump sucking are 2/ is the skimmer box at the pool full of leaf matter 3/ I have the pump impeller got leaf of rubbish in it. Check these items first.
Jul 05, 2014 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
It stopped pumpin water, doesnt turn on. its a well pump for my house water
This pump turn to go death all of the sudden, the coil inside the engine get fried all of the sudden. How old is it?
Thanks
Jun 23, 2011 | Sta Rite Sta-rite .75 HP Shallow Well Jet...
To purplewg re my Sta-Rite pool pump: I haven't disassembled anything yet, because I'm trying to get an accurate dx before delving. If I take the thing apart, I'll have to replace the seal, and I'd rather...
Jun 17, 2010 | Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
Spa Motor Hums
David
May 17, 2009 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
The pump works for a minute with the jets, then sops, then starts
You need to check the door on the skimmer and the water leavel on the pool. If the door is stuck or the leavel is low the pump will **** the skimmer dry and cause the problem your describing. Try these first and good luck.
Mar 17, 2009 | Sta Rite Sta - Rite 2hp Max - E Pro...
Jacuzzi jet pump doesn't produce much bubbles
you need to turn the air on should be some sort of cap or screw in type thing to let the air in open it
Jan 17, 2009 | Pool & Spa
Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out, Center Discharge, 240V, w/Hair & Lint Pot Logo
88 people viewed this question
Top Sta Rite Pool & Spa Experts
john h
Mike
David Spradling
David Spradling
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
