Vacuums Logo
c
colleen morris Posted on Jun 25, 2014
Why is my VAX 121 blowing my fusebox ? - VAX Appliances Vacuums
juliana samson
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Jun 25, 2014
juliana samson
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
9897
Points
60
"Blowing" FusesWhen a fuse blows, replace it with an identical [same Amperage rating] new fuse.
IF the replacement fuse also blows, then that is an indication that there is either a short circuit condition in that circuit, OR you have an overload condition due to too many electricity using devices connected to that circuit, or one that draws too much electrical current [current is measured in Amperes (Amps), or milliamps (thousandths of an Amp)].
The fix" for repeatedly blowing fuses is to troubleshoot the circuit involved, find and identify the fault, properly repair it, and then install another good fuse
Does the vax 2000 need a bag
Yes, this uses a Bag. AF482 Starbag from Cleanstar.
if the bag is not in properly or damaged it may blow thru.
1helpful
Why do my VAX 651546 keep blowing fuse box after being turned on for a few moments ?
When a fuse trips, the current was to high. If the fuse keeps tripping, you really have a problem. It could be as simple as a defective capacitor, but also a shortage in one of the coils. It would be wise to bring the VAX to a repair shop and ask what it will cost to repair. Sometimes when they need to replace a motor, you are better of with a new machine.
I hope it is a minor defect.
Success
Old vax vacuum wet and dry keeps tripping fusebox after about a minutes use.
there may be a broken wire within the cable or in the actual plug
Sep 19, 2011 • Vacuums
2helpful
Manual for vax 121 wet & dry hoover
I need a VAX wet/dry vacuum model 221-07 manual.
3helpful
VAX HOOVER PROBLEM?
The 121 should only have the main filter ring taken out before the reservoir tank is put in which easily just falls into the main dust tank area. Make sure though that the bin's square edge is at the front where it rests at the front of the Vax where the hose comes out. Then unhook the pump to lay it in the water tank and the motor should be able to jam ontop clipping both sides down to lock. Perhaps you are putting the reservoir bucket in the wrong way.
Jan 12, 2009 • Vacuums
Vax v-60P turboforce pet bagless upright 2000w
hi phoned vax today.. they said there's definately NOT a problem with that particuliar model. I now have to send the 2nd cleaner back to them to repair...If this problem occurs again they will replace it with another model!!!
so watch this space!!!
I think having two vacs blow up is too much of a coincidence!
I have been using vacs for nearly 40 years & I've never had this happen before!
If Anyone comes across the same problem I would appreciate you letting me know.
Thanks for your time
Liz
Top VAX Appliances Vacuums Experts
john h
Are you a VAX Appliances Vacuum Expert? Answer questions, earn points and help others
