Question about Umax Astra Office Equipment & Supplies
Driver windows 8.1 - Astra Umax Office Equipment & Supplies
I lost HP drivers or Windows 7 drivers when I installed Windows 8.1, where can I find the drivers?
If you are using Windows 8, most probably your Windows 7 drivers wont work.
You can find the drivers for Windows 8 of your original HP components in HP website
See Support - Download Drivers
Apr 25, 2015 | HP Computers & Internet
Pebble 3 windows 8 driver
Use the pebble 4 driver. I am using windows 10 and have tested on 8 as well. Download the Pebble 4 windows 8 driver and it will work fine.
Mar 19, 2014 | Evolis Pebble Color Card Printer
Can asus k42f be ugraded to windows 8?
Windows 8 has updated drivers as much as you would get from Asus built into win 8.
Go to devise MGR, if windows 8 did not load drivers, you will see a flag.
See what hardware did not load a driver and then use the win 7 driver.
You don't do anything to make a win 7 driver work, if the driver is newer, and signed it will install, if it's older then the driver windows installed, it won't install. If you see a flag and windows did not install a driver, then try the win 7 driver, or go to the MFG of the hardware and see if there is a win 8 driver.
You can also run windows update, if win update see's a newer driver out it might pick it up and give you a install option.
Now, your chipset, and most hardware has windows 8 drivers out.
The drivers are the biggest problem, the biggest problem for you is the BIOS was not set for windows 8.
So you could find even with the best drivers, win 8 slower or has bugs more then win 7 will have.
Me, I would bench test all the hardware with win 7, then with win 8 and see which one is better.
Apr 08, 2013 | ASUS K42F A1 Notebook
FS-720 Driver for Windows 8
Click the link and scroll down to the Windows 8 Section
Windows 8 Driver
Feb 03, 2013 | Kyocera FS-720 Laser Printer
Pacific Image PrimeFilm 1800u Film Scanner : is there a Windows 8 driver out there somewhere? Can anyone offer some help in finding it?
PrimeFilm 1800u will not work on Windows 8.
Here is the response I received from the company for the question:
Where can I get drivers for windows 8? Windows 7 drivers are not working on Windows 8.
Response:
Hello, This scanner will not be supported on windows 8, all of our USB 1.0 technology scanner will no longer be supported beyond Windows 7.
Wendy
Dec 19, 2012 | Pacific Image PrimeFilm 1800u Film Scanner...
After update to windows 8 - drivers not working for asus k50ij.
Windows 8 is brand new and they may not have the drivers that you need for your computer on line. You may need to call them and ask them to send you a cd/dvd with the drivers for your computer. It is not always wise to upgrade your computer immediately when a new program such as windows 8 comes out. My advice to you is to reinstall your last windows back on your computer for now and if you want to upgrade to windows 8 check to see if all the drivers are available ahead of time, before you upgrade.
Nov 20, 2012 | Computers & Internet
Top Umax Office Equipment & Supplies Experts
Michael Thomas
Michael Thomas
Mike
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
