try a reset first, you can do it by pressing both home and power button at the same time until you it displays the Apple logo, when you see the logo, let go of the buttons.
If that doesn't fix it, then you need to re-install IOS.
Hello, you will need to Flash the Field. With the generator running, plug a drill motor into one of the 110 volt recepticles. Now for the DANGEROUS part. Pull the trigger on the drill.........now with the other hand..........Quickly spin the chuck. DONT hang on to the chuck. The drill should start to run. ..Your done. If it doesnt work, spin the chuck the other way. This polerizes the stator and will work.
As soon as you turn your computer on, and see the Dell logo, start tapping the F2 key. If you miss this window of opportunity, wait until Windows has fully loaded, then restart your computer. Try again.
(The Dell logo comes up pretty fast. If you miss entering BIOS Setup, {System Setup is Dell's term}, then as soon as you press the Power On button, start tapping on the F2 key. Tap in 2 second intervals)
