The battery draining of power when motor is swiched off
TO CHECK FOR A BATTERY DRAIN. TURN OFF EVERY SWITCH IN THE CAR. CLOSE
THE GLOVE COMPARTMENT. MAKE SURE THE LITE IN THERE IS GOING OUT. OPEN
THE HOOD CLOSE ALL OF THE DOORS. MAKE SURE ALL OF THE COURTESY LIGHTS
ARE GOING OUT. DISCONNECT ANY UNDER HOOD LIGHTS. DISCONNECT NEG. BATTERY
CABLE. USE A 12 VOLT TEST LIGHT, FASTEN ONE END TO THE NEGATIVE BATTERY
TERMINAL, FASTEN THE OTHER END TO A METAL PART OF THE MOTOR. IF THE
LIGHT COMES ON, THERE IS A BATTERY DRAIN. NO LIGHT, NO DRAIN. IF THE
LIGHT IS ON, PULL EACH FUSE, BIG & SMALL, ONE AT A TIME, OUT OF THE
FUSEBOX THAT IS NEAR THE BATTERY. WHICHEVER FUSE MAKES THE LIGHT GO OUT
IS CAUSING THE DRAIN. IF THE LIGHT STAYS ON THROUGHOUT THE FUSE PULLING,
DISCONNECT THE ALTERNATOR. IF THERE IS SOMETHING WRONG IN THE
ALTERNATOR, IT CAN DRAIN THE BATTERY WHILE SITTING STILL, EVEN THOUGH IT
IS CHARGING THE BATTERY WHILE YOU ARE DRIVING. GOOD LUCK
