It tells me I have to refer to the manuel I don't have the manuel and I cant find another action replay like it the new ones are all updated :(
SOURCE: ACTION REPLAY DS PROBLEMS
The AR should come pre-loaded with codes for most games. If you followed the directions carefully and there are no codes for your game I suggest following the AR update instructions in the booklet to reset and download the most up to date codelists for your games.
SOURCE: action replay code manager doesnt see the action replay
Many are experiencing this, what you are looking at here is a faulty action replay. go to the Datel website and submit your serial number to them, it will immediatly say whether or not your AR is from the time period when they had a problem with the internal USB reading system, if it is, then send it in and one will be shipped withing 10-12 weeks
SOURCE: my action replay code manager is empty and I want to add pokemon
Heres your problem, I believe you just recently purchased this AR, the new version of action replay require a software update found on Datel's website, after downloading this software your Domain Suffix of your Optical Drive will automatically replace the program with the newer one. Open up your winsock processor and buffer the Native file of your AR back into your fluxus core before adding codes to your action replay, if this does not fix the problem, submit a complaint to the Datel Hacking Team located at PO box 45265 North Ridge, CA. This whole process should take anywhere from 10-12 weeks to fully resolve
SOURCE: My Action Replay doesn't work with ACWW
People had gone to extreme measures to fix this problem, when the answer is right in front of them! :P
Yes, Animal Crossing Wild World v.1.52 does NOT work on Action Replay. However, v.1.1 does. Notice that there are two versions of Animal Crossing. If Animal Crossing (the default one) goes to a black screen, and doesn't load anymore, delete that file, and use the other one where it says v.1.1. The codes does not work, but click "START" anyways. Notice how there aren't anymore black screens. Turn it off, and don't load your game. That's where the easy part comes in. Just replace the old codes, and use the v. 1.52 codes (that you can find at Codejunkies.com). It'll work perfectly fine.
I know it was frustrating for you, because it was for me too. But fortunately, I found the solution, and I'm happy to share this with everyone. Have fun!
Which by the way, I forgot to mention that since the default Animal Crossing WW file has been deleted, and the game ID is different than v.1.1., you must click the star on the bottom left corner, and click on Animal Crossing V.1.1. yourself. It won't load automatically like it did before, but it's no troublesome, I SWEAR!
SOURCE: My DS action replay is broken
If you hold A B START AND SELECT at the same time, with the power OFF, then turn it on with your thumb or something and let go when it says the product isnt endorsed with nintendo. hope it works good luck =)
