Question about LG WFT1071TP Top Load Washer
Why is lg top loading washer taking hours to wash
5 Suggested Answers
Toby Gomes
  • 38 Answers
SOURCE: LG Top Load Washer
this could be a drain hose loose or broken if the leak only occurs during rinse. If it leaks all the time, could be a broken outer drum or worn tub seal.
Hold inner drum and turn bothways. If it turns bothways, you have a bad bearing, and hence, a bad tub seal. If it turns in one direction only, bearing's good; but tub seal could still be bad.
Posted on Jul 23, 2008
Anonymous
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
Anonymous
SOURCE: my lg top loader washer continously drains water and never washes
I was solve resolvbe it in a most simple way.
Posted on Jan 31, 2010
DOUBBLEJ34
  • 523 Answers
SOURCE: my lg washer seems to take forever when it gets to
check the filter
Posted on Apr 21, 2010
Matt Ace Appliance
  • 311 Answers
SOURCE: How do you take the top off of a LG Tromm front
theres three screws in the back that need to be removed. then you push the panel towards the back wall, it slides back then you can remove it. Good luck. _MJ_
Posted on Apr 22, 2010
How long should a complete regular load take?
A regular load should probably take approximately 40 minutes, but there are various times for every different washer. The washer I have at home takes about 50 minutes to an hour. It really depends on the quality of the washer. Certain washers today use less water therefore it takes longer to wash
Feb 12, 2018 | Washing Machines
Lg top load washer 1 year old, vibrates violently during spin. Checked an adjusted level, no help.
they have springs and shock absorbers in the machine to help stabilize the load when spinning. since the washer is so new, i would guess one or the other has just come loose. take top off and check. online videos will show you how
Feb 24, 2016 | LG WT4801CW Top Load Washers
LG WaveForce top load washing machine flashes unbalanced on every single load. Even when run completely empty. a single load can take up to 6 hours to complete.Manufacturer nonresponsive. Solutions?
LG issued a recall on certain waveforce washers due to the unbalanced error codes. You may have a washer that is affected. Contact LG at 855-400-4639, and have you model number and serial number at hand to see if you need a software update.
Jan 25, 2016 | LG Washing Machines
Drain er at 30 min to go in wash
lg takes too much times to continue washing when it arrives at 17 min. it takes more than an hour
Dec 22, 2012 | LG WFT1071TP Top Load Washer
Own a lg wm1832cw front load washer doesnt seem to clean properly when wearing tee shirts for an hour smells like they never were washed paid alot of money for this thing seems cheaper top load machines...
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Sep 12, 2011 | LG WM1814CW Front Load Washer
Whites don't get clean in front loading washing machine
I have the same problem and I'm really aggrevated that I paid alot of $$ for something that doesn't do the job it was purchased to do! I'm going to look at replacing it with a top loader. I think LG should take responsibility for selling a bad product.
Jul 15, 2009 | LG WM1814CW Front Load Washer
The washer takes forever to complete it will take
front load washsher do take longer to wash than top load but it should not take 2 hours on a short cycle. has it always done this
Jun 23, 2009 | LG WM-2277HW Front Load Washer
Front-load washer doesn't clean!
I don't know anyone who thinks the front loader is better except for stacking things on top of...
Certainly the performance of the modern water-saving front-loader is questionable when compared to earlier models - which is why I think a wash takes much longer these days with a modern machine, I think it has to in order to be effective. My friend's new front loader can take a couple of hours to complete a programme and it is only a washer and not a waser/drier.
The older washers used to take everything that could be pushed inside and the laundry would emerge smiling. These days overloading is a complete taboo and should be weighed to ensure nothing is strained.
Your washer might have a fault but in the final analysis you made a contract with a retailer to, in return for a consideration, supply you with a washer to clean your laundry. The supplied washer doesn't clean the laundry in spite of your best efforts and that means the retailer has broken the contract. It is up to him to sort matters out to your satisfaction.
Mar 25, 2017 | LG WM2016C
How long should a normal wash cycle take on the whirlpool duet?
One hour and 10 minutes is normal for your washer. All front load washers take a long time. They wash a lot better than top loaders. So to answer your question.. yes its normal.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WFT1071TP Top Load Washer Logo
252 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
