Question about Goodman CKL24AR24 Air Conditioner
If you have a split unit, it is fairly simple, just feel the small refrigerant line coming out of the unit. The temperature should be warmer than the surrounding air. If is not running the temperature will be the same as the surrounding air. If you have a package unit, take off the access cover to where the compressor is located. Find the compressor discharge piping to the the condensing coil. It is the smaller of the two major pipes on the side of the compressor. Be careful the temperature of line coming out of a properly operating compressor will be hot enough to cause second degree burns. If the line is very warm to very hot the compressor is running. If you have a set of gauges, attach the RED hose to the high pressure service connection and the other low pressure hose BLUE to the bigger pipe low pressure connection. Make sure the gauges are isolated by shutting the valves. The pressure difference between high and low pressure is normally at least 150 psig diference.
Posted on Oct 14, 2014
Jul 01, 2018 | Danby Heating & Cooling
Jun 28, 2017 | Bryant Heating & Cooling
Jul 07, 2016 | RVs
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
May 03, 2014 | Heating & Cooling
Jun 10, 2011 | 1999 Ford Expedition
May 28, 2010 | 2005 Buick Rainier
Mar 08, 2010 | Air Tools & Compressors
Feb 07, 2009 | Dometic Rooftop RV Air Conditioner
Jul 08, 2008 | Dometic Rooftop RV Air Conditioner
65 people viewed this question
