Question about Motorola L3208A MC3000 Digital Junction Box
Why Busy Light stays lit and desk sets do not connect
Motorola Mobility
  • Official Brand Answer
  • 3,100 Answers
Contact Motorola Solutions. Http://www.motorolasolutions.com/support
Posted on Jul 30, 2014
I have a display light lit up & I would like it off on my panansonic KX-DT343
Have you had a look in the menu and look for display backlight and set it to off that should solve that little problem.
2answers
Pilot light wont stay lit on gas logs
If the pilot lite comes on, but will not stay on after it has had enough time to heat the thermocouple, you got a bad or the wrong thermocouple. It does take some time to heat that thermocouple.
2helpful
My Netgear wireless router wgr614v7 has limited or no connection to computer through any of the LAN ports. LAN port 4 stays lit all the time, and is lit in conjunction when any of the other ports are...
Hello
There should be a reset button on the back that will bring this back to factory defaults. HOWEVER, every time I have seen "the light stay on" the router or switch was bad,. I would return this unit.
Best of luck
I have a (HP L1730) flat panel monitor that im trying to use with my HP Compaq 6910p Laptop. When I power on the monitor,there is a quick 1 second flash of my desktop on the screen,then it goes to a black...
Does it do the same when it is hooked up to desk top PC?<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span>
I have a set of propane gas logs. The pilot light
Check the connection of the thermocouple or replace it if connections are tight.Pilot safety valve may be badreplace gas control valve.
1helpful
One of the Co lines. CO 4 has a constant fast "busy" tone when off hook. Bad CO card?
The red light will stay on until you clear the alarms. Those alarms can be for any reason, so the idea is to just ignore them and let a technician read them when he comes.
If you don't have a Line 4, it will give you a fast busy because there's no dial tone. Just because it appears, and you can select it, ie green light and display saying Line 004, if it has no line connected to it, you will get a busy. Either get dial tone on the line, disable it, or take it off the set. The first is in program 400, the second is PROG press the button press TRANSFER twice and STORE.
Carl
Internet connection
1. Power off the modem. 2.Restart your computer. Allow the system to stabilise and switch on the modem after about 10mins. Check for connection. If nothing happened after all this, then go to Device Manager and scroll down to Modem. Click the plus sign and lookup for that particular make. It may be disabled. If disabled, simply right click and select Enable and wait for about 5mins to login. Good luck
1helpful
Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
2helpful
FWD/DND light is on and so is an extension light but the FWD/DND setting is off but when i check messages, i get a busy signal.
If the FWD/DND light is lit solid, the extension is in DND if it's programmed properly. You can test this by pressing the FWD button and reading the display. It will clear and press it again and it will set and tell you what it did. (if DND and FWD are both set it shows 3 states).
At the phone, press intercom and dial *710x where x=2 for all calls, 3 for busy, 4 for no answer or 5 for busy/no answer plus the extension of the voice mail plus #. Your FWD light should blink and you have now set FWD to voice mail.
Carl
Open Questions:
See all Motorola L3208A MC3000 Digital Junction Box Questions
Motorola L3208A MC3000 Digital Junction Box Logo
Top Motorola Televison & Video Experts
Joaquim Martins
ray gallant
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
