Question about Samsung WEP200 Headset
Trying to connect my august ep650 headphones to esynic AD2P bluetooth
My headphones wont work on my laptop
Because you use the word 'pair' I have to assume that your headphones are Bluetooth-enabled. If this is the case, you can pair and connect the headphones to your phone and/or your iPad, which are, like most, if not all, phones and tablets, Bluetooth-enabled. On the other hand, very few desktop computers and/or laptops are Bluetooth-enabled. Your computer does not recognize your Bluetooth-enabled headphones because it is not Bluetooth-enabled.
Dec 26, 2014 | Audio Players & Recorders
Bluetooth paired but not coneected
How to pair and then connect to a Bluetooth device on your T-Mobile G1 Google smartphone.
1. First, ensure Bluetooth is enabled.
2. From the Home screen, press Menu.
3. Select Settings.
4. Select Wireless controls.
5. Select Bluetooth settings.
6. The G1 starts searching for Bluetooth devices in range. Select the device when it appears.
7. Type the PIN for the device.
8. The device should then pair with the G1. You can then select the device name to connect.
Bluetooth only supports ad2p profiles for headsets, music, and sharing of contacts and pictures. This is limited by VZ. Until the phone is rooted, there is absolutely no way around this. You cannot send files other than contacts and pictures via bluetooth.
It sucks... I know. I am in the same boat. I am [im]patiently waiting for the droid to be rooted so I can use bluetooth to share files between two droids.
Feb 24, 2012 | T-Mobile G1 Android HTC Google Smartphone...
My blackberry 8520 wont recive music via bluetooth
You need to make sure that your bluetooth device supports AD2P.
Jan 16, 2011 | RIM BlackBerry Curve 8520 Smartphone
I don't know how to use the Bluetooth on my iPod touch I want to send some songs to my cell
To turn on bluetooth on the iPod- settings>General>Bluetooth>On. iPod Touch will only detect AD2P Stereo Headsets, not mobile phones, none AD2P Stereo Headsets, and others. hope this will help. Enjoy !!! Thank you for using Fixya !!!
Nov 14, 2010 | Computers & Internet
I am conneted to the car system but no audio in coming or out goig calls
The only thing i can think of is that it might the bluetooth protocol used by the two are not completely compatible. Look in the manual for the stereo and see if the bluetooth is AD2P if so then the hero doesn't support that type of bluetooth stereo. best guess
Jul 28, 2010 | HTC Hero Smartphone
Just bought the brookstone wireless tv headphones. I have a Westinghouse 40 inch lcd tv. I plugged in the rca red/white into the audio out and I don't get any sound into the headphones?
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
May 09, 2010 | Brookstone Surround Sound Earbuds...
Connecting two devices on BT3030 headphones
A method to do pairing in "the second channel."
  1. Trun off BT3030 first.
  2. Continue pushing the power button till "Jabra" mark turns on pink next.
Attention: Continue pushing the power button after "Jabra" mark became the blue.
Mar 11, 2009 | Jabra BT3030 Wireless Headset
Setup Bluetooth Wireless headphones
Each brand has it's own peculiarities and you did not specify the brand. I would suggest turning off the headphones, resetting the transmitter (turn off and on again for separate devices) and then pressing and holding the 'on' switch for 15 seconds or so. You may see (in some models) a light start to blink blue then red and back. This should indicate that the receiver (headphone) is trying to find a transmitter to pair with. Hope this helps.
Nov 27, 2007 | Logitech Bluetooth Wireless Headphones
Samsung WEP200 Headset Logo
Top Samsung Radio Communications Experts
Jean Thiebaux
Lawrence Oravetz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
