Question about Yamaha Electrical Supplies
Why does my yamaha gas generator gas leak - Yamaha Electrical Supplies
What type/size sparkplug should I use in my ef2500 yamaha gas generator?
The Yamaha EF2500 portable generator uses a NGK spark plug #BPR6HS. Just bought on this week at the local NAPA store to replace the old spark plug in my generator.
Tom in Lafayette, IN
Nov 12, 2010 | Garden
3000 watt yamaha generator is really hard to start and when started it stalls under load.
sounds like the carberator needs cleaning and the linkage that makes it open up under load. it works off the flywheel. a lot of generator problems are gas related. water, trash and varnish build up in the carb.
Aug 25, 2010 | Yamaha 4500 Watt Electric Start Generator...
What steps do I take to get a Yamaha EF1000 gas powered electric generator going again after it has been sitting around for years with gas in the tank? How do I drain the gas from the tank and carburater?...
You can disconnect the fuel line from the carb and drain the gas. It would be even better to then remove the fuel tank. If this is the generator with the large plastic tank, quite often the rubber gromet in the bottom of the tank with shout off vavle in it will deteriorate into a black gooey mess, and leak. If so that will have to be replaced. Clean inside of tank with fresh gasoline. Remove bowl from carburator and clean throughly. If you know how to work on engines, remove the carburator and clean throughly, notice how all springs and linkage were connected before removeal. Be sure all passage ways in carb are clean. Always use sta-bill in your gas.
Jul 23, 2010 | Yamaha Electrical Supplies
Can the ecu memory be flashed on a yamaha EF2800iportable generator? My 2800i will start and run for about 90 seconds and then shuts down. Carb is fine. Two issues: 1. It is not generating...
It sounds like its running on the gas in the carburetor and not the gas filling back up to run more, I bet you have a gas supply problem to the carburetor! Try Babbitts Yamaha Partshouse online...
Mar 12, 2017 | Yamaha 1,000 Watt Portable Generator...
Conversion of yamaha gasoline generaor into natural gas...
i know YAMAHAwere doingsome work on converting outboard motors to run on LPG they may be able to get a bit of info from the STATE distributors might be worth a phone call
Jul 20, 2009 | Electrical Supplies
Electrical Supplies Logo
66 people viewed this question
Top Yamaha Electrical Supplies Experts
Sheldon Dedek
Robert Wooley
Robert Wooley
Dan Horsefield
Dan Horsefield
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
