Question about Vehicle Parts & Accessories
I need a Installation manual for Ungo 5100 serial 052628 car alarm?
Car alarm system in isuzu rodeo?
Kardoc
    Top Expert:
  • Vehicle Part... Master
  • 5,976 Answers
3 Related Answers
Anonymous
SOURCE: spy car alarm manual
Forget the advice on how to steal a car. It's pointless and does nothing to answer your question. I suppose alicantecoli is proud of his abilities (I used to be too, but I don't do that anymore), however he is a fool if he thinks a 2-Way alarm is useless. While it may only take him minutes to disarm the alarm (waaaaay too long), with a 2-Way system & GPS tracking it would only take me seconds to find it again. Or you could use the silent alarm feature, allow the car to be stolen and immobilise it in the middle of the road. Beside all of this, a simple set of relays properly wired to monitor the alarm system power status can turn those few minutes into an hour or two. Anyway, to your question.
The install manual for the (rebranded) Spy 2-Way Car Alarm is a pathetic chinglish translation printed on a single sheet. It would do you no good unless you have some experience with electronics, and a working knowledge of your car's wiring. That being said, here's the wire colours for you:
6-Pin Connector:
Purple : A/C
Brown: On
Yellow: Start
Red: 12v+
Black: 12v-
12-Pin Connector:
Central Locking - it depends on the type as to how you wire it...
Yellow: Nc
Y/Black: No
White: Com
W/Black: Com
Orange: Nc
O/Black: No
Brown: Flash Lights
Brown2: Flash Lights
R/Black: Trunk/boot release
Red: Siren
8-Pin Connector:
Red: Window roll-up
Green: Side-door + trigger
Blue: Side-door - trigger
Yellow: Engine cut-off
White: Acc
Orange: Foot-brake
Purple: Handbrake
Grey: Start-sensing
2-Pin White: LED
2-Pin Black: Temp. Sens.
3-Pin White: Shock Sens.
3-Pin Black: Microwave Sens.
These four plug in in this order: 2PW, 3PB, 2PB, 3PW
Inside the unit (under the sliding cover on the top) there are three jumper settings: Elec/Pneu CL, Lights Flash/No Flash, Auto-arm/No auto. The first of each pair is the default setting.
Hope this helps. That, honestly, should be all you need. If you do need more info, then please DO NOT TRY TO INSTALL THIS ITEM YOURSELF. As it says on the manual, "Install the system by a professional people."
Posted on Feb 18, 2009
Don Casillas
  • 24 Answers
SOURCE: Clarion ungo alarm model 5100
Can't seem to locate a manual. Just get into the wiring under the dash and follow the larger wires from the alarm brain and cut each wire, one at a time, from the factory ignition harness them tape. Start with just the starter wire to see if that fixes the issue for now. If this problem just started, check to see if there is a tach wire that runs under the hood to a coil or injector. If this wire is disconnected the remote start won't see the car is started and will continue to crank the starter.
Posted on Nov 04, 2009
Anonymous
  • 344 Answers
SOURCE: I need to find an installation diagram for a 2001
www.bulldogsecurity.com
Posted on Jan 08, 2010
2001 Isuzu Rodeo wont start and alarm light blinks as soon as you open the door and if i leave the key open check engine comes on and blinks every seven to ten minutes
need to check for fault codes for the engine and the security system. the problem may be connected somehow, but it sounds as if you may have multiple problems.
Jun 17, 2012 | 1998 Isuzu Rodeo
How do you disable a 2001 rodeo sport alarm
You can't disable a factory alarm system short of completely rewiring the whole electrical system and writing and installing the software programs it runs on.
Mar 17, 2012 | 2001 Isuzu Rodeo
2000 Isuzu Rodeo (just purchased), anti-theft alarm goes off periodically for no apparent reason. Was going to remove fuse, but it is already gone. How can this be possible, unless someone has bypassed...
THATS WHY THEFT SECURTY ALARM GOING OFF THEFT SECURITY SYSTEM NOT WORKING FUSE IS MISSING.MORE LIKELY THE GUY SOLD YOU THE CAR BECAUSE OF FAULT IN THE THEFT SECURITY SYSTEM, GOING COST TO FIX.
May 30, 2011 | 2000 Isuzu Rodeo
Just bought a 2000 Isuzu Rodeo that didn't come with an owners manual or a clicker for the alarm system. How do I disable the alarm. Is there a switch in the vehicle that would disable the alarm? The...
There are fuses associated with the security system that you might try pulling out. The car may not start though if the circuit is not made.
You might want to consider buying a new remote. It can be programmed to your car and you can leave the security system intact.
Apr 15, 2011 | 2000 Isuzu Trooper
I have an ungo remote start/alarm. This AM the car would not start and the alarm went haywire- kept going off, took control of the car, A/C going on and off, etc. Had to disconnect the battery to get it to...
i have a ungo sr 6000 i missed placed my lcd 2-way remote so i only have the secondary 4- button remote. How can i disable the timer auto start!!!!!!!!! PLEASE HELP ASAP !!!!!!!!! GOIN BROKE ON WASTED GASSS!!!!!!!!!!!!!!
Jul 30, 2010 | Ungo SR6000 2 Way Security with Remote...
Isuzu rodeo 2000, LS, anti-theft alarm needs to be reset
This has to do with the Auto's Computer system and should ONLY be done by a Factory Rep who knows what he/she are doing. not a home mechanic chore!!
Jul 16, 2010 | 2000 Isuzu Rodeo
Nov 03, 2009 | Ungo S670 Car Alarm 2way LCD & 4butt Rem
98 isuzu rodeo factory car alarm
There is a separate computer box for the car alarm, try disconnecting the wiring harness that goes to it.
Aug 07, 2008 | 1998 Isuzu Rodeo
Vehicle Parts & Accessories Logo
226 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
