SOURCE: Car is smoking on start up, a lot of white smoke
If the engine is using oil then first remove the dipstick and run the engine, check to see if heavy smoke is coming out of the tube, this would indicate worn piston rings,if it is not so dense, yet you are using oil and it smokes bad from the exhaust, then its likely the valve seals are worn. either way, unless you have mechanical knowledge, tools etc , you need to take it to a mechanic for the engine repairs or live with the oil consumption. There are no quick fixes for engine wear.
