Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Why wont one of two beaters stay locked in in Kenmore 16 speed 350 watt mixer?
5 Related Answers
Anonymous
SOURCE: KitchenAid Hand Mixer Beater won't stay in slot
You need a new gear set.  Hard to find however.
Posted on Oct 14, 2007
Anonymous
SOURCE: kitchen aid tilthead mixer will not lock down
The solution for both of these is a large screw that sits at the base of the head where the head and the base meet - you'll see it when you tilt the head up. This screw should not be all the way in. You can adjust how low the head goes- in the case of your blades hitting the bowl you'll want to let the screw out a bit; in the case of the locking, you'll want to screw it in a bit more.
Posted on Mar 17, 2008
Deerdoc
  • 7 Answers
SOURCE: KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Posted on Dec 15, 2008
hslincoln
Howard Lincoln
  • 235 Answers
SOURCE: kitchenaid 625 watt 6 quart mixer. Was using it
HAMILTONCOOL - It appears that your mixer had a mechanical failure in the transmission box or planetary gear assembly of your mixer failure - one of the main gears has failed, hence the loss of power to the agitator. You didn't mention any associated noise prior to the loss of power to your agitator, but I'm assuming there was just a little more noise than usual, prior to failure.
The inspection and troubleshooting of the transmission is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you're lacking one, you can download it from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, and then select Parts List file. You can check the page titled 'Case, Gearing & Planetary Unit, for the disassembly, troubleshooting, and reassembly of your mixer, along with all the parts. It can be messy but gratifying. Once apart you can check for any other unseemly wear and tear on the gears, etc. Good hunting... I hope this helps - Howard, Burke, VA
Posted on Nov 19, 2009
hslincoln
Howard Lincoln
  • 235 Answers
SOURCE: Have a kitchenaid artesian mixer need to adjust
Hi KELLYSERMAN, this should be pretty easy to do by yourself the instructions for adjusting your beater to bowl clearance is in your Owners Manual. I you don’t have the original manual you can easily download a PDF version of your Owners Manual from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150 and select the file listed for your model that appears under Owners Manuals (66): KSM150PSER1 (732.33KB) and save that file to your PC. Turn to Page 14 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
I hope this helps! – Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Posted on Dec 07, 2009
My kitchen aid mixer has two problems. One, the bowl doesn't stay locked in its seat. Runs for 10-20 seconds and boom it's loose. up and down.
that mixer has two different beaters one for next to the outside of the bowl and one for the center of the bowl if you get them backwards the beaters will bounce on the side of the bowl
Dec 30, 2017 | Food Mixers
We have a Cuisinart Hand Mixer Model # HM70 and the Beaters do not stay in the mixer holes. Can this be fixed in any way? Jack
Cuisinart hand mixers are not repairable. You can buy replacement accessories like beaters, but you can't buy any internal replacement parts.
I have a Cuisinart HM-70 and I stripped the plastic gears inside by trying to mix a really thick dough. It was easy to open and get to the plastic gears. When I called Cuisinart to try to get replacement gears, they said that they don't sell replacement parts and their hand mixers are not repairable. I looked all over the internet and no one sells internal parts.
Unless your mixer is still under warranty, I believe that you're out of luck and your mixer is headed to the electronics recycle pile.
Most handmixers today are sold with plastic gears - including high end brands like Viking. For me the lesson learned is to buy low end hand mixers (don't buy a top of the line 9 speed mixer) and treat them like they're disposable when they break.
Dec 03, 2010 | Cuisinart HM-70 220 Watts Hand Mixer
The beaters will not stay in i cant find the inststruction-can y
Here is a link to the manual:
http://www.cuisinart.com/share/pdf/manuals/hsm-70.pdf
The key: One beater has a wide disc on the handle - this one locks into the wider beater slot.
Jul 24, 2009 | Cuisinart HSM-70 220 Watts Hand/Stand...
New beaters
go to this site and you can order on line or by phone.
www.a1service.com/toastmaster.htm - 52k
please rate my answer. thanks
Feb 06, 2009 | Toastmaster 350 Watts TMSM350 Stand Mixer
One beater one stay in socket with use
They are plastic with a small spring ring around the end of the spindle. If the beater is faling out, you need a new spindle.
Jan 16, 2009 | Toastmaster 200 Watts 1719 Hand Mixer
Lost beaters
Either call or contact the company by phone and ask for assistance in replacement parts.
Jan 05, 2009 | Betty Crocker 340 Watts BCF1250 Stand...
Sunbeam 2484 Beaters won't stay engaged.
In taking apart my same beater, I'm trying to figure out the alignment of the spring which provides the tension so that the beaters won't fall out. I'd assume that your spring has mis-aligned. You need to take it apart (3 Philips screws), and carefully pull the assembly apart. I'll bet your spring falls out like mine did. I'm trying to find a schematic from Sunbeam to see how the spring should align.
Nov 19, 2007 | Sunbeam 200 Watts 2484 Hand Mixer
Jan 07, 2007 | KitchenAid KHM3 Classic Hand Mixer
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
137 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Colin Stickland
Colin Stickland
Lee Hodgson
Lee Hodgson
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
