Samsung Blackjack SGH-I607 Smartphone Logo
Question about Samsung Blackjack SGH-I607 Smartphone
How to change domain\username on my corporate emaill on my Samsung sgh t-399 phone
1 Related Answer
leorcid
Arun John
  • 281 Answers
SOURCE: i need to install email on my SGH E251
Call the customer care and ask them to send settings to your mobile or ask them to tell you the settings so that you can enter them manually.
Posted on Apr 11, 2009
What is the hotmail setting for samsung galaxy GT-S5670
Tap open your application.
then select email(default app)
add new account and choose others
fill your email address and your password of your hotmail account.
preaa manual setup then choose exchange account.
for domain or username fill your [email protected]
fill in your password
fill in your exchange server as m.hotmail.com.
tick or check use secure connectio (SSL)
press next then select the sync options you like.
for exchange server it will all depend on your software versuon or firmware version. Exchange server doesnt work now with 4.2 4.3 and kitkat. If you encounter this issue restart again and choose either pop3 or imap.
goodluck and hope this helps you.
3helpful
2answers
Email stopped working
Have same problem with our corporate phones. No solution, other than installing k-9 mail
I have a Samsung Ace phone. Somehow the btinternet email has dropped off, and although I have tried to add it on again I'm unsuccessful! It keeps asking for my domain. What would that be? I must have a...
FIXYA does not repair your lost password for any device,you need to contact the customer service for the thing (phone)that you have lost the password for,thank you.
Can't get my work email to work with the phone security settings?
Q: How do I set up corporate e-mail?
A: This setup enables you to wirelessly synchronize your email and other information directly with the information stored on a Microsoft Exchange Server.
From the programs menu, tap Accounts.
Tap Add account.
Tap Corporate Sync.
Enter the domain, username, pass-word, e-mail address, and server for your Microsoft Exchange e-mail account.
Tap Next.
Note: Contact your company's IT department if you need more help. This feature works with Microsoft Exchange e-mail servers
5helpful
2helpful
Need to change user name and domain on Outlook email account
You cannot modify your existing ActiveSync partnership.
You must go into ActiveSync options on your phone and delete the partnership.
Note that deleting the partnership only deletes the copy on your phone. It will not delete the source mailbox on your server so don't worry.
Once that is done you can set up the new partnership with your new server.
I hope this helps.
2answers
Unable to send txt msg with pictures on SGH-U600 unlocked!
Goto this website:
http://uk.samsungmobile.com/supports/supportMain.do?&menuIdTop=00000000000003
On the left hand side under configure phone it says WAP and MMS settings
To send picture messages it is the MMS settings you need
Click on the MMS and follow the instructions
2helpful
2answers
Setup gmail on my samsung i600
I can access gmail on my phone; it's fairly straightforward: - unlock the keypad - hit the 'envelope' button at the bottom right to go into 'Messaging' - select the bottom item: "New Acccount" - choose "Other (POP3/IMAP)" from the e-mail provider list and hit Next - Enter your name and email address, then hit Next (leave the "Automatic setup" checkbox ticked; it makes no difference) - hit Next again to skip the automatic configuration - enter your gmail username (with the @gmail.com bit; I like to use the recent:[email protected] to download only the most recent emails) and password. Leave Domain (if necessary) blank and hit Next - choose server type "POP3", account name "Gmail" and select whatever network (WAP Gateway or Internet) you want to use, depending on how you want to connect - Enter the following - - Incoming Server: pop.googlemail.com - - Require SSL connection should be checked (ticked) - - Outgoing Server: smtp.googlemail.com - - Outgoing server requires authentication should be checked - - Outgoing server configuration: - - - Use different user name for outgoing server (if you've used the recent: username for downloading email) - - - Enter your gmail [email protected] - - - Enter your password - - - Leave domain blank and check "save password"  - - - check "Require SSL connection" - - - then click Done - - Select however many day's worth of emails you want to download and click Next - - Select "Never" to connect automatically if you aren't on an unlimited data tariff! - Click Next then Finish.
Hope this works!
Email
Which ever application you use (let me know specifically), you will almost always choose creating a POP account. You need from your service providers the following items.
  1. SMTP domain (ie. smtp.domain.com)
  2. POP domain (ie. pop.domain.com)
  3. Username to your email (ie. [email protected])
  4. Password for this account.
Your ISP will most likely have instructions about how to connect to them. If you go to their support and type in POP3 with Outlook or Outlook Express. You'll most likely get a hit.
In Outlook, go to Tools | Account Settings | Email to add the accounts.
Hope this helpa, if it does, please choose FixYa!
ThankYa!
Cannot Send or Receive Email
This may happen if your Internet connection uses dynamic DNS. Change the email application to use a fully qualified domain name for the login. A fully qualified name is composed of both the host and domain. Correct: yourusername.aol.com Incorrect: yourusername The correct fully qualified name can also be derived by putting your router's username and domain name together as they appear on the router's setup screens. E.g., if username = sueandfred, and domain name = aol.com, then the fully qualified name = sueandfred.aol.com. (Note the dot between the username and domain.)
Top Samsung Computers & Internet Experts
Ekse
Muzahura Frank
Marvin
Marvin
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
