Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Akai PT5598HD 55 in. Rear Projection
My Akai PT5598HD 55 in. Rear Projection has been making cracking and popping sound in the past, and last night the sound went out completely. This morning the sound was back on, but I had to leave to go the work, please advise.
Posted by robbigabe on
John
    Problem Solver:
  • 8 Answers
Something like this Id have someone who knows there way around electronics, a qualified tech or someone you trust really well :-) Does the crackling affect the TV picture at all ? My first guess would be dust and or dampness on the audio components. Sometimes this can conduct electricity across small pc chips and reak all sorts of havoc. I had an old Tomas electric organ once, and it actually caught fire because two speaker wires were rubbing together and eventually wore thru the insulation and shorted out, but it was also making alot of crackling and static noises. Try raising and lowering the volume low to high and high to low and see if the crackling noises gets worse. Some audio amplifiers put out quite a bit of power, so I wouldnt trust leaving the TV on without a fire extinguisher handy.
Posted on Jan 28, 2008
Akai PT5598HD 55 in. Rear Projection HDTV-Ready Television tv looks like it is now 3d model with red out by about a half inch. will not adjust on converage settings
sounds like your convergence board has failed ...there may be a kit at tvrepairparts.com..there you can search your model number for a convergence repair kit...you will need to have someone with electronics repair experience install the parts if you do not know how yourself...these kits range from 40.00 to 100.00 and usually come with a cd or dvd to aide in installing these components.
Dec 20, 2010 | Akai PT5598HD 55" Rear Projection...
AKAI PT5598HD will not turn on.
if you got to the following link and search by the model number you will find what your looking for.
Http://www.samsungparts.com/search/search.asp
The part number for the service manual is SM-PT5598HD
As the set is showing a blinking red timer light. you can check the following link out.
http://www.techlore.com/article/15444/
May 13, 2008 | Akai PT5598HD 55" Rear Projection...
Have sound but no picture
Ur Video board backlight,is dead,must be replaced.
Sep 21, 2009 | Akai PT5598HD 55" Rear Projection...
Akai model pt5598hdx/sms
it would sound like your convergence amp power board has failed at the shop we would replace then it would need a serviceman alignment
Jun 17, 2009 | Akai PT5598HD 55" Rear Projection...
AKAI PT5598HDI 55" PROJECTION TV HAS POWER AND SOUND, NO PICTURE
Open the back of the tv and check Fuses, sound like the high volt over loaded
Jan 11, 2009 | Akai PT5598HD 55" Rear Projection...
REAR PROJECTION TV NOT TURNING ON
I just got this tv free and it will stay on for 15-30 minutes and then turn off. Some times it will stay on all day, though, so its kind of weird. I have the 5499HD
Dec 29, 2007 | Akai PT5598HD 55" Rear Projection...
Describe your Akai PT5598HD 55 in.
looks like you have a convergance problem akai is made from samsung
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 17, 2007 | Akai PT5598HD 55" Rear Projection...
Akai PT5598HD
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
128 people viewed this question
Top Akai Televison & Video Experts
Ekse
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
