To clean contaminated ISV of Robinair 34700Z, open front lower panel, then slowly disconnect 3 hoses from ISV (Liquid, Air purge and Vapor). Now unscrew ISV tank from machine and then fixed an adapter to Liquid port of the tank to allow all the contaminated refrigerant to go out from tank. after emptying the tank, if possible make vacuum for approx. 10 minute with an external vacuum pump. Replace everything its original location after completing vacuum. Now change spin-on filter (Located on the back side of the machine) and vacuum pump oil. Your machine is now ready to work.
Thanks and I hope this will help you to solve your problems.
This is a common problem of Robinair 34700Z / 347002K &
347112K series machine. So don't worry just do the following, with POWER SWITCH
OFF: - 1# Open front panel cover and verify the ISV tank is not overfilled. If full,
carefully remove refrigerant manually from ISV tank by pressing tank valve. 2# verify
if there is high pressure in the ISV tank. Purge excess air from the tank
manually. (Open air purge hose from the ISV tank, then carefully press tank
valve as needed to blow out excess pressure from the ISV tank)
After doing all above stapes and your problem still exist then
replace air purge solenoid (Air purge solenoid located near the ISV tank and
fixed with automatic air purge device). Hope this will solve your problem, if
so please vote for it for farther help! Good luck
If your machine is one of the bellow Model:- Robinair 34700Z / 347002K & 347112K series.
just do the following, with POWER SWITCH OFF: - 1# Open front panel cover and verify
the ISV tank is not overfilled. If full, carefully remove refrigerant manually
from ISV tank by pressing tank valve. 2# verify if there is high pressure in
the ISV tank. Purge excess air from the tank manually. (Open air purge hose
from the ISV tank, then carefully press tank valve as needed to blow out excess
After
doing all above stapes and your problem still exist then replace air purge
solenoid (Air purge solenoid located near the ISV tank and fixed with automatic
air purge device). Hope this will solve your problem, if so please vote for it
