GE JASRM24912 Remote Control Logo
Question about GE JASRM24912 Remote Control
I have a panasonic universal remote UR77EC2408 and need to program my tv
Need codes or need to know how to get my original protron remote to function with my protron tv
Posted by Cheryl Tonelli on
5 Related Answers
Anonymous
  • 50 Answers
SOURCE: remote code for my ge universal remote
http://www.jascoproducts.com/support/universal-Remote-codes.asp
All GE UNIVERSAL remote codes.
Posted on Nov 18, 2007
Anonymous
  • 3 Answers
SOURCE: universal remote
Codes for Panasonic TV.....171,148,054,170,062,374,381,437,003,070. You can Goggle the programming info...Just ask...How do I program a GE Universal Remote... There are about 7 steps...easy if these codes work....good luck...I have a remote that none of the given codes are working........
Posted on Nov 29, 2007
Anonymous
  • 156 Answers
SOURCE: I need the programming instructions for GE RC24912-D universal remote
I have emailed you the manual you wanted.
Posted on May 14, 2008
Anonymous
SOURCE: PROGRAMING MY GE UNIVERSAL REMOTE RC24912-e 5811
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
Posted on Mar 17, 2009
Anonymous
SOURCE: Direct Entry Code for GE television for GE RM24911 Universal Remote
NECESITO HOJA ADJUNTA DE CODIGOS DEL RM24911 POR FAVOR
Posted on Apr 14, 2010
How do I attach my protron TV with a universal remote?
To attach your Proton TV with a universal remote, you will need to first program the remote to work with your TV. This can typically be done by following these steps:
  1. Locate the remote code for your TV in the manufacturer's instructions or online.
  2. Press and hold the "Program" or "Setup" button on your universal remote until the indicator light turns on.
  3. Use the remote's number pad to enter the code for your TV.
  4. Press the "Power" or "TV" button on the universal remote to see if it turns your TV on and off.
  5. If the TV does not turn on and off, repeat steps 2-4 using a different code for your TV.
Im trying to program a Panasonic universal remote to clear tunes tv
Search Results
    Need codes for ct-300 clear tunes universal remote - Fixya
    www.fixya.com/.../t17341079-need_codes_ct_300_clear_tunes_universa...
    Mar 26, 2013 - need codes for ct-300 clear tunes universal remote Need codes - Symphonic ST419E TV ... Universal remote code for a panasonic ct-27g14a.
    I have a clear tunes tv and trying to program my RCA universal
    www.fixya.com/support/t25649135-clear_tunes_tv_trying_program_rca
    Apr 16, 2015 - ... a clear tunes tv and trying to program my RCA universal remote to it ... "I need to program an old Panasonic TV with a RCA universal remote ...
    I need the codes to a clear tunes remote for a rca - Fixya
    www.fixya.com/support/t3026751-need_codes_clear_tunes_remote_rca
    Sep 26, 2009 - I need the codes to a clear tunes remote for a rca tv. ... "I need toprogram an old Panasonic TV with a RCA universal remote model RCR311St ...
    Radio Shack panasonic remote control codes clear tunes tv ...
    www.fixya.com > ... > panasonic remote control codes clear tunes tv
    ...remote. the panasonic codefor my radioshack 3-in-one remote is 0250 I need a codefor a VCR Durabrand (DCV603) for the Sony universal remote control or a ...
    Clear tech tv 4 digit code - TV - Other Consumer Electronics
2answers
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
2answers
Program RCA universal remote with Panasonic TV
If you have the owner manual for the remote try all the panasonic codes or google for that with the model number of the remote--not all remotes will program for all models and if programs it may be missing key features the original remote had.
Protron lcd tv installing a universal remote but no where to turn on tv. old remote has gone out
It is preferred to have the TV on when programming a remote,but usually not necessary.If you enter the programming codes in the remote,it should be able to turn on the TV if the code is correct.(The remote puts out the same command to turn the TV on or off).
1helpful
2answers
I need the code for program my universal remote for my32" protron model lu32A1A3
what is your universal remote model? here are the universal codes for most models of remotes 1004 or 1011 let me know if it worked
What is the remote code number? my remote is not working and I am trying to program a universal remote, but can't find a code (protron pltv3250)
If your universal remote has a code search function (most do) you may have to try that. Allot of off brand tv's are manufactured by other companies. Check the back of the TV to see if there is a label that says "manufactured for Protron by ..." If a code search doesn't work post back with the brand of remote and we can try help you further.
3helpful
"I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help""I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help"
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
Replacement remote or code
Punch in the code #0003 to program a universal remote...
Top GE Televison & Video Experts
Jaime Hernandez
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
