Television will not turn on. Checked outlets already.
SOURCE: I have a Olivia television flat screen. after a
If u have no power lites lit up on the tv, then it may just be a blown fuse. if not then the power supply board would need repairs. should be taken to a shop
SOURCE: the television just won't turn on but my outlet
The first thing you should do is open it up and check for a blown fuse. I have serviced several LCD TVs with blown fuses on their powerboards, and I assume plasma TV's use conventional fuses as well.
You should be able to bring the fuse into radioshack for a replacement.
SOURCE: SANYO Model CLT2054 Television
same problem, sound no picture. took it off wall disconnected power and smacked it a couple of times. Plugged it back in and works fine
SOURCE: My television will not turn on. I made attempts
No power to the tv at all?No,LED power light indication or no LED power standy light.The tv power supply board is dead.That the board,where it take in the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
SOURCE: Remote sensor on the APEX
The set is slow to respond but you must have a clear shot at the lower right corner of the set. That is where the signal is received. Our sofa cushiopn sometimes gets in the way and must be moved. When a signal is received the blue light comes on.
Your RCA rear projection TV may not turn on from time to time for several reasons. First, check that the power cord is plugged into a working power outlet. Check that the outlet is receiving electricity by plugging a different device into the outlet. If the other device doesn't work, you may need to replace a fuse or reset a circuit breaker in your home.
If you tried using the remote control to turn on the TV, press the "Power" button on the front of the TV. You may have a problem with the remote control if the TV turns on.
If you tried using the front control panels and haven't tried the remote, press the "Power" button on the remote control. The television controls are blocked if the TV turns on with the remote. To unlock the controls, open the "Parental Control" menu and remove the check mark next to "Front Panel Block."
Finally, your TV may be performing a diagnostic check. These checks are used to find any errors in your TV. Wait a few minutes before trying to turn on the TV again.
You may find that your RCA TV turns off by itself on occasion. This is often because the "Sleep Timer" feature was enabled. This feature allows you to place a timer on the television that will turn it off after a specific amount of time has passed. The feature allows you to save on your energy bill and extend the life of your television.
If the "Sleep Timer" wasn't set, the television may have detected a power surge in your home and shut off automatically to protect the components of the television. Wait at least 30 seconds before turning the TV on again.
Finally, if you suspect the television is turning off for a reason other than a power surge, unplug the television and let it sit for at least 10 minutes. This will clear any errors in the television. After 10 minutes, plug the television back into the outlet and resume normal use.
A blank screen on an RCA rear projection television is usually caused by a loose connection or an incorrect setting. Check that the coaxial connection on the back of the television is secure or, if you're using an external device such as a DVD player, the video cables are secure. Press the "Ant/Cable" button to switch between tuners if you are watching television, or the "Input" button to switch between input channels if you're watching something from an external device.
