Question about Lorex 4 Channel Home Surveillance System
How do i get the night vision picture to come in better on the moniter
The picture comes in very cloudy and dark and u cant see nothing
Posted by jamie robinson on
J.D. Browning
  • 2,760 Answers
INSTALL A EXTERNALL ILLUMINATOR IN VIEW AREA IT HAS IT'S OWN POWER SUPPLY , AND NEED NOT BE NEAR CAMMERA ONLY IN IT'S VIEW AREA THIS WILL INCREASE BRIGHTNESS OF VIDEO IN DARKNESS
Posted on Dec 05, 2014
Dark cloud thick lines appearing on my LCD TV
It sounds like a loose contact to your T-con panel. Before the problem happened, had you recently moved your TV? A picture would help my friend also if you have the model number.
Jun 17, 2013 | Televison & Video
No flash. pictures are dark
My Kodka M530 is only taken dark pictures, I cant get the flash on, and if I get it on it still wont stay on. The pictures still coming out dark
May 18, 2010 | Kodak EasyShare M530 Digital Camera
Very dark picture. Video adjustments do not help.
I would check the lamp first. Open the lamp door to see if there is cloudiness near the stem of the lamp. If so, replacing the lamp should make the brightness like when you first bought it.
Oct 11, 2009 | Sony KDF-E50A12U 50" LCD HDTV
Cloudy picture
NO, IF YOU SPILL ANY OF THE FLUID ON THE BOARDS THEY ARE RUINED AND ALSO IF YOU DO IT INCORRECTLY THEN YOU WILL HAVE TO RECONVERGE THE ENTIRE SET AND THIS TAKES A LOT OF TIME AND SKILL.
Sep 14, 2009 | Televison & Video
Need to fix the color and screen
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Nov 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Ezonics IcatchVI PC Camera Ez307 help????
Something probably corrupted your webcam software or configuration. Probably the best is to uninstall and reinstall the drivers and the software.
Please check http://www.pcauthorities.com/pc-errors/how-to-fix-webcam-problems
The drivers should be here: https://www.shopezonics.com/Articles.asp?ID=108
Jules
Oct 16, 2008 | Ezonics EZCam Plus Webcam
S5200 does not correct for light conditions anymore.
You should reset to default the camera settings if you're not really sure what to change...but I thing the exposure has to do with the lighting conditions and also the picture mode(indoor, cloudy, night, sunny etc.) See if any of these will help you.
Sep 02, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Adjusting darkness
Hi Angel,
Are you really sure , your set has video? How dark is it ? As if really nothing visible? Am, sure you can hear sounds. You can adjust the brightness + button to increase the brightness. But if nothing happens , you have problem with your TV set. The problem might be in the Video section. Please let an expert technician to check it. Please don't do it by yourself, it's risky.
Please send feedback whatever comes up. So we can help you further in the future.
Thanks,
Eriez
May 26, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Lorex 4 Channel Home Surveillance System Logo
133 people viewed this question
Top Lorex Home Security Experts
Alphanso Tee
Fred Kommeroh
Level 1 Expert
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
