Question about Samsung Rv511
My problems is : cannot see any indicator (light bulb,probably) to show if my caps lock is off or on, Ihave a sumsung rv511
Posted by Bruno Russo on
JonSnell Electronic
    Top Expert:
  • Samsung Master
  • 31,846 Answers
If there is one it will be top right of the caps lock button.
Posted on Jun 24, 2014
Samsung R511 blinking orange with battery in its slot/place. Removing battery results in green light but laptop does not boot...not even bios screen. ..just remains dead. Laptop works normal with charged...
R511 or RV511-a01. use correct model?
R511 is DVR player, so I call TYPO.
answering for RV511 now. ( 8 years old at least)
Notebook NP-RV511 , this? with windows 7 still?
you said it runs normal with a charged battery
is that history past or now.
then you said, remedy, and my socks fall off
what? "without battery and work on AC, no battery)
so you are saying the power pack is dead.
buy one, end this saga., $15 power pack off fleabay.
the #1 cause of bad troubleshooting is Assumptions/.
like my battery is good, you'd need a same PC known good to know that and test the battery there.to prove that. Batteries are the #1 failure mode of all PCs made. period. so.... even 1 year old !!! abused.
no battery lasts 8 years, ok
ECON110 , no tools , no meters, no spare parts to do tests. (am i right)
1: runs on AC ok battery out buy a new battery for $15
2: runs on battery only but not on AC only
buy a $15 AC power pack. (a dmm meter used now will prove its bad, (we test at the mobo jack live)
3: runs on AC but the new battery will not charge,
buy new mother board, the charging chip on board is toast $300
econ 101 wins lacking tools
or get the PC serviced in shop that has tools.
Aug 08, 2018 | Samsung Computers & Internet
Red light
Try firsd doing a complete defrost, leave fridge unplugged at least 24 hours
May 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Turn off caps lock
Great little utility. I think it's free. Will show in your taskbar.
Here is the link.
https://www.traystatus.com/
Oct 08, 2017 | Computers & Internet
CANT TELL IF MY CAP LOCKS ARE ON OR OFF WHAT DO I NEED TO SELECT TO KEEP THIS FEATURE
if your caps light is on a light will/should show on your keyboard
hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/numcapsscroll-indicator/3000-2072_4-10604212.html
On-screen real-time indicator showing the status of the Num, Caps and Scroll Lock buttons on the keyboard. NumCapsScroll Indicator monitors their status and indicates it in the System Tray with its icon, with a tool-tip when you mouse-over its System Tray icon, with a small On-screen Keyboard-like panel and a sound indicator. It's also an identical utility for laptops that are not supported with Num, Caps and Scroll Lock LEDs on their Keyboards.
What's new in this version: Version 7.0 is compatible with Windows 7.
Apr 06, 2011 | Computers & Internet
Ihave hp pavillion dv7 1245dx when you power up it acts like its locked in hibernation everything is on and the cap lights blink but the screen stays dark ...
I suggest try to do a Hard Reset on your machine by removing the Battery, unplugging the Power Cord and after that Press and Hold the Power button for about one minute without any supply on the machine. After that put it all back in and see if still doing the same problem, If its still doing the same problem count the blinking lights on your caps lock it indicates what could be the hardware that's faulty on your machine then call the manufacturer's tech support and tell them that it gives you that kind of problem.
Feb 16, 2011 | HP Pavilion dv7-1245dx Notebook
My sumsung U5 mp3 player device showing in computer but the files is not showing and not opening
If the player is showing but not the files it will be good to use a search on the drive- the player as the search object- for all types of files.
If there is some lock on the files then it will not show up and will need to check if the folders are locked, but a search will indicate al files which can be opened.
Also in the first place check the properties of the player which will indicate the memory used in the player.
Feb 12, 2011 | Samsung YP-U5 MP3 Player
Is there a light that should come on when I press the num lock button? I can't tell if the number lock is on???
It depends on the keyboard model. Some have a number lock indicator light. There is no standard for location, either. The most common place for Caps lock, number lock, etc. on a desktop keyboard is behind the number key pad. However, some keyboards put the caps lock indicator right in the Caps lock key. There's probably at least one model that does the same for number lock. Many laptop models have no indicator, or a tiny one set somewhere in back bezel.
Some operating systems and applications have an option for displaying the status in the menu bar. If you can't find the number lock status indicator, you may have to resort to observing the behavior of the system when you hit a key on the number pad. If number lock is off, the even numbers (not including 0) will be arrow keys and the odd numbers will be page navigation keys.
Jan 20, 2011 | Computers & Internet
Low Fuel Panel Indicator On
I know if your gas cap is leaking the low fuel light will come on but I never heard of the gas guage showing empty unless you have a float problem. The float is in the tank.
Jan 01, 2009 | 2002 Ford E350
I HAVE A COMPAQ PRESARIO V6000 AND THE CAPS LOCK LIGHT IS NOW NOT WORKING AND WONDERED IF THIS IS A BULB PROBLEM OR WIRING PROBLEM?
You can try attaching an external keyboard using a USB or PS2 slot in your laptop. If the light goes on in the keyboard but not in your laptop, probably it's the bulb of your laptop.
Aug 30, 2008 | Compaq Computers & Internet
Caps lock
Good morning, luckypenny1!
To answer your question- Most laptops do not show the caps lock status on the task bar.
As you have probably noted, the caps lock indicator is located to the front, left of the keyboard. Not sure why they decided to place it there as it's usually covered by your left hand when typing. Maybe they built it that way for people that only type with their right hand? ;o)
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Dec 01, 2007 | Fujitsu Siemens AMILO Pro V2010 Notebook
Samsung Rv511 Logo
67 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
