Zenith Z50PX2D 50 in. Plasma HDTV Logo
Question about Zenith Z50PX2D 50 in. Plasma HDTV
If your tv doesnt have coxcial can you hook your cable up with anything besides a vcr
How do I hook up my ps3 to my rca colortrak?
would be best to get a old vcr, then with a cable you hook it to the vcr and play it thru the vac
2answers
I have purchased Samsung 550 - series L5 - I don't seem to be able to hook up the VCR to it to record. I have cable on it and I would like to be enable to record programs. Television ask if I want to...
You don't record from TV, you record from cable so cable needs to be hooked up to input on VCR.
If you don't use cable box you would hook cable to VCR then out of VCR to TV. If you use cable box then you need to connect Video and Audio outputs on cable box to Video and Audio inputs on VCR and switch input of VCR to Line input.
I have an apex dvd vcr tv the vcr doesnt work vcr doesnt work how
Video out on tv ? If yes just standard rca cables and vcr in video input mode. If no then you`re out of luck.
How to hook up a tv to a reciever??
If unit does not have in/output jacks, you can't hook up amps to it directly. However, you can use the cable input from VCR or VTR , then patch in A/V equipment to them. Make sure to switch TV to cable in
2answers
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
2helpful
3answers
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
1helpful
Connecting VCR/DVD combo to TV
If that is the only input that the tv has it's still usable. Just plug the Cable TV or antenna cable into the DVD/VCR coaxial input labeled "in" (instead of the TV's) and hook one from the DVD/VCR's "out" to the "in" on the tv. Turn the TV to channel 3 or 4 (depends on DVD/VCR settings) and use the built in TV tuner on the DVD/VCR to change channels.
Recording instructions
First, whether or not you can do this will depend on cable box useage, and how the VCR is hooked up. In the earlier days of cable TV, & off-air reception, this was a simple task. If you have a satellite receiver box or cable box which is used to tune the channel, rather than using the TV itself or the VCR tuner, then recording one channel while watching another may not be possible. While I don't know the capabilities of newer sat/cable boxes, older ones sent just one signal out to the external equipment (TV etc.) That one signal (channel) is all that is available. If you received a manual with the sat/cable box, see if it says anything about this issue. That being said- if you don't use a sat/cable box, but instead use your TV or VCR to select the channel you are watching, then assuming the VCR is hooked up inline with the TV, just setting the VCR/TV option to TV will pass all channels through to the TV, and you can then use the TV to select whatever channel wished, while the VCR is recording something else. Hopefully I haven't confused you. If another contributor has some additional info on the capabilities of sat/cable boxes of today, please read their contribution.
Top Zenith Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
