Question about Sanyo DWM400 DVD Player
Why does my dvd player says no disk when it is loaded?
I tried ka cleaning disk, however same problem sensor doesn't sense the disk.
SDVD7040 7" potable dvd player SYLVANIA How do i
Go to Staples. They sell every type cleaning kit imaginable and can recommend the best for you.
Sep 19, 2017 | Televison & Video
The dvd player side doesn't want to read all discs. Some it just flashes the loading and makes a clicking sounds, sometimes it loads up and freezes on dvds, it does this when i try to put in a cleaning...
The clicking is made by the laser head as it moves across the surface of the disk repeteadly trying to pick up the data signal and failing.
If it has used to work then it's clearly a dirt problem. If a cleaning disk has failed to work then the dust has gone all the way to the reading sensor. To clean it you will need top completely dismantle the unit access the optical mechanism, take off the cover and access the reading head - there blow with the can between the lens and the sensor then with a q-tip wipe the surface of the lens.
Sep 17, 2011 | Philips Magnavox DVD/VCR Dual Player
Dvd player tell me disk error
this could be aproblem with the lens which is unable to read the disk. this could be caused by accumulation of dirt on the disk sensor. open up the cover of the dvd player to access the lense and clean gently with a lense cleaner(a liquid purposely meant for cleaning the lense) apply this liquid on a soft piece of cloth and clean. close back the cover and power the dvd player it should now be able to load the disk
We have an LG DVD DR7621W and it keeps telling us no disk although we have put a disk in.
try to insert other disk, make sure the file format with in the dvd that you use is applicable to the dvd player if not it will not recognized.now if still other dvd's doesn't read try to clean the optic sensor with cd lens cleaner might be dusty.another way is manual cleaning with the use of smooth cotton buds with isoprophyl alcohol wipe the optic sensor do this gently not to damaged the optic sensor. good luck hope this will help you.
Jul 18, 2011 | LG Televison & Video
Displays no disc
1.) If your display is no disk it's possible that your disk you inserted is corrupted or dusty, try to clean your disk with wet clean cotton.
2.) If does not work it is also possible that the CD is only a pirated, try to insert original CD and play it.
3.) If does not work again, try to remove the cover of your DVD and checked all the connections of the DVD connector from the circuit board, try to reconnect the connector and tightening it.
4.) Common problem from the DVD player is the sensor from the DVD reader checked if it is dusty or not, tries also to clean it with clean cotton.
5.) And if you try all of these method and your DVD still doesn't play again, it possible that the sensor from the DVD reader is defective try to replace the sensor with the help of technician.
May 29, 2011 | Sungale DVD-2026 DVD Player
I have lg DVD player and it says no disk when i insert the dvd it
MBB, First clean the CD/DVDs in plus manner. Up -down and right - left. And not in the usual circular as most of us try to clean them. Use a soft dry cloth.
Jun 04, 2010 | LG KU990 Viewty
Suddenly my DVD player is saying "no disc" after trying to load DVD. Why isn't it sensing the DVD has been loaded?
When a DVD goes into DVD player it has to spin it and read it. If your DVD player is not reading the disk. The disk could be dirty. The DVD player might need to be cleaned. You could be trying to play a PAL disk on a NTSC player or Visa Versa. or the region coding might be wrong. Try playing a clean disk that you have played in it before. That might tell you if you need to clean the DVD player.
Mar 03, 2010 | GoVideo DV2130 DVD Player/VCR
Screen says loading and after a while, says disk error.Then eject
hi try first to insert a clean up CD, and test your DVD player with an original DVD, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
sserpentio
Apr 12, 2009 | Televison & Video
Toshiba sd-4990 dvd player will not load a disk
Your toshiba is not spinning that's why it keeps on saying loading. Unplug the dvd Open the device,once open plugin the dvd and put the dvd cleaner in the player. take your finger on the top where the dvd disk is and spin the disk. What happening is that you are cleaning the len. keep spinning until it spin on its own.Put the toshiba top back on and clean again. It should clean on it's on. Now you can play your dvd. Clean your dvd on a regular basic.
Mar 12, 2009 | Televison & Video
I insert disk but it doesn't load. It says no disk.
The disc won't start spinning until the player senses the disc is there. If the lens on the laser inside that reads the disc is very dirty, it can cause this problem. You might try cleaning the lens with a cotton swab moistened with lens cleaner or isopropyl alcohol.
Nov 11, 2008 | Venturer 3.6" Portable DVD Player
Sanyo DWM400 DVD Player Logo
80 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
