There are several reasons why your Crosley top load washer might not be passing the wash cycle. Some common causes include:
- Power issues: Check to see if the washer is properly plugged in and the outlet has power.
- Water supply problems: Make sure the water supply valves are turned on and the hoses are not kinked or clogged.
- Load balance: The washer may not be able to advance to the next cycle if the load is unbalanced. Try redistributing the clothes evenly in the drum.
- Control panel issues: The control panel or the control board may be faulty and need to be replaced.
- Lid switch: If the lid switch is not functioning properly, the washer may not be able to advance to the next cycle.
- Clogged pump or drain: If the pump or drain is clogged, the water may not be able to be pumped out of the washer, causing it to stop mid-cycle.
If you are unable to resolve the issue on your own, it may be best to consult a professional for further assistance.
