Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
Your biggest suspects will be a bad connection or relay on the control panel, a bad connection on the magnetron terminals, a bad magnetron, a shorted high voltage rectifier diode or a bad high voltage transformer.
You can find exploded views and part numbers by entering your model number at the
Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
You may be able to find better part prices than Sears
here.
Your magnetron may have a 5-9 year warranty, so check your manual for that. Sears may send you a magnetron if it's bad and warranty.
