Question about Sharp AR-5316 Advanced Digital Imager Copier
SharpAr5516 copier my sharp copier ar5516 is plashing E240.how do i reset the code?or what might be the problem?
Gift Ntwana
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Check the scanning operation with
SIM 1-1.
Posted on Apr 21, 2016
5 Related Answers
Anonymous
  • 62 Answers
SOURCE: Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
Posted on Mar 23, 2008
Anonymous
SOURCE: Help
Sorry bubbabear 64, you are wrong you need to reset the copier with sim 14, once you have cleared the jam, there is no sensor in the fuser so often if the paper gets crumpled in there is doesnt trigger and sensors so the customer trys to copy again and again, seen it many times.
John Sharp Tech
Posted on Jul 22, 2008
tehnik_bdg
Budi Raharjo
  • 91 Answers
SOURCE: Sharp SF 2030 Copier ,need reset operator key code
First you need to know the key operator code, you can display it by pressing [C][INTERUPT] [0/ZERO][INTERUPT][22][START][13][START] then the display will shows you the 5 digits key operator. After you know the key operator code, you can go to User program, this is done by pressing [C][INTERUPT] [C] then input the key operator code, when entry is complete "P" will appear in the quantity display. Input 19 then START, input the new code and press START. To exit user program press CA
Posted on Jun 05, 2009
rezazadeh
abbas rezazadeh
  • 328 Answers
SOURCE: Code
how input code(# interrupt C interrupt)
Posted on May 30, 2010
Rick Kasper
  • 2072 Answers
SOURCE: in sharp ar5516 F2 CODE DISPLAYED
Try this. On the panel. Press # * C *. Your screen will change to a diagnostic mode.
Enter the number 14 , as if you were going to make 14 copies.
You may have to enter 1 , then press start. But follow the display directions.
The 14 will clear F codes. This should resolve your problem.
Posted on Feb 22, 2011
My copier sharp-ar5516 is indicating error code F5 00 what's problem
on your ar5516 f5 error code would be a copy lamp problem, lamp bad or the fuse or a connection.
Apr 11, 2017 | Sharp Office Equipment & Supplies
HOW TO FIX ERROR CODE 444 BLINKING FOR SHARP AR-5516?
http://www.sharpmea.com/cps/rde/xbcr/documents/documents/om/34_ppc/AR5516-D-5520-D_OM_GB.pdf
May 20, 2014 | Sharp AR-5320 Black and White Copier
Sharp ar5516 f2 error
We have bought this machine on Date-28/07/2011 and it is still in warrenty. now already 11,000 copies put it And the now machine shows F2 indication after starting and the company not repairing it. And the after sell service of company is not good.We tell the company to change the the machine or repair and they neither repairing it nor changing the part.
I request you to solve my problem please.
Nov 14, 2011 | Office Equipment & Supplies
What is a trouble clear
according the manual F2-04 means drum data read problem,may be it can be reset.
1, power on,
2, press "clear","interupt", "0", "interupt"
3, press 14 prss start
4, press clear
Nov 01, 2011 | Sharp AR-5316 Advanced Digital Imager...
Display error code E7
Sharp copier AR5516 not working. Error code E 7 kindly help.
Jul 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
How to enter in simulation mode of sharp ar5516s for eradicating an error like drum reset and developer rest for this model please tell the complete procudure and code i am sorry am new to this.
perform the following procedure to enter the simulation mode :-
press " # " key >> " Interrupt " key >> " c " key >> " Interrupt " key >> " 42 " >> " start" >> " 1" >> "start" ( this to reset the the drum indicator and replace 42 by 20 to reset the maintenance indicator).
I hope this help
Feb 17, 2011 | Sharp AR-160 Copier
Code
Mar 03, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
27 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
