Question about Tag Heuer Kirium (CL1212.BA0705) Wristwatch
How do I get new band for aquaswiss anchor in green
4 Related Answers
vsndesigns
Victor Noda
  • 5 Answers
SOURCE: how to adjust the band on a aquaswiss trax watch
Warning: This is if you don't have any professional watch tools. And I definitely recommend you taking it to a jeweler first.
That being said...
I was able to adjust my band by using a small nail and a pair of needle nose pliers...and Krazy Glue or Super Glue (last warning...you really should take it to pro)...
1. Push the any one of the pins that holds the wristband together until you see it protrude from the other side. While applying pressure to the pin, quickly grab it from the protruding side with the needle nose pliers and pull off the metal cap from the pin.
2. Note you will notice that the pins are actually 2 pieces! They are not screwed together and it makes for a pretty poor design since, one the pins are taken out and then replaced after taking out the appropriate links... they tend to get loose and you will lose that tiny metal cap that holds the pin in place.
3. A professional will have a clamp that is small enough to press these two pieces together. But even that is precarious. I strongly recommend that you carefully apply a drop of crazy glue on each end of the pin, after you are finished.
Final note: I was luck to have spare pins from the links I removed to replace the pin that worked out of its cap. That little sucker is lost to the watch gods. Have fun! Also... you can make final adjustments at the 3 pin location at the wristband release.
Hope this was helpful!
vsndesigns
http://www.rgmarchitect.com
Posted on Jan 25, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: How do you adjust the Band On an aquaswiss Trax?
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Feb 15, 2009
Anonymous
  • 56 Answers
SOURCE: How do I get a steal band for my Aquaswiss Trex watch?
look for a tag store near by. if u cant find one most jewelry stores with a shop (not in a mall) can either do it there or send it out. sometime the band can be fixed
Posted on Oct 08, 2009
Jimmy Accardi
  • 101 Answers
SOURCE: my dog ate the band on my aquaswiss swissport
You can call Tag Heuer and order a new band or you can try online sources such as ebay who sometimes sell them at a lower price.
Posted on Oct 20, 2010
How do you re3move a link from a Casio watch band
take it to a jeweler and they will send it to casio to remove a link. The clip may have movable anchoring points . You need a pin to push in the pins inside the link on both sides. then move the link and re anchor the band under the clip.
Jan 25, 2015 | Casio Mens WV58DA-1AV Waveceptor Atomic...
Just got myself the new SWISSport M but it not moving
Your watch is a battery powered watch. If it is not running, the first thing to check would be the battery. To turn it on just push the crown in.
Oct 07, 2012 | Aqua Swiss Aquaswiss Trax Wrist Sharp...
My dog ate the band on my aquaswiss swissport purple watch. where can io order a new one?????
Oct 19, 2010 | Tag Heuer Kirium (CL1212.BA0705)...
Looking for an instructional booklet for my aquaswiss sport watch
Thank you for contacting FixYa.<br /> Very difficult to find certain odd brands such as Aquaswiss. You wil have to contact them direct at :<br /> <a href="http://www.aquaswisswatch.com/Scripts/contactUs.asp">http://www.aquaswisswatch.com/Scripts/contactUs.asp</a><br /> <br /> Best regards,
Aug 25, 2010 | Bulova Watch
Unable to locate original replacement band - nylon
The only place you can find an original band is through the actual vendor. Try this.:
TG Service Center
Returns Department
1302 Pike Avenue
North Little Rock, AR 72114 Phone: 800-448-4639
Email:[email protected] Your only hope to find a band is if someone is selling like watch on Ebay, craigs list, etc and it is in new condition. Hope this helps.
Jul 21, 2010 | Timex 27191 Wristwatch
Oct 07, 2009 | Tag Heuer Kirium (CL1212.BA0705)...
Ironman Triathlon Sleek Ladies watch Band problem.
try simple free or a citrus solution often found in household cleaners. js
May 24, 2008 | Watches
Aquaswiss Trax watch band adjustment
VSNDESIGNS SAYS:
You should first try to adjust the band at the Clasp first. The clasp has three holes that you could easily move your band up or down into. If you need to remove one or more of the links, try the following.
http://www.fixya.com/support/t315141-adjust_band_aquaswiss_trax_watch
Feb 09, 2008 | Watches
How to adjust the band on a aquaswiss trax watch
That being said...
vsndesigns
Dec 25, 2007 | Tag Heuer Kirium (CL1212.BA0705)...
Tag Heuer Kirium (CL1212.BA0705) Wristwatch Logo
26 people viewed this question
Top Tag Heuer Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
