SOURCE: Replacing the Drive Belt on a Poulan Riding Mower
Without an impact, it's will be more difficult. The only way to get back-up on the bolt is to remove the screen over the flywheel on top and put a socket on the flywheel nut
SOURCE: the star mounts on my poulan 42'' riding lawn mower
Without knowing your mower for sure, I think I know what you may need to do. Most often, you just need to remove the block that the pattern is on. These are most often bolted onto the shaft. If you don't have your parts book for your mower, you may bee able to look it up online.
SOURCE: what size drive belt does a 38in deck require?
it depends what kind of mower you have, i have a 38'' mower that uses a 14'' belt.
SOURCE: I have a Poulan riding mower and it has a 42
The easiest way is to find your owners manual and find the picture of the belt in there. Using the picture as a guide you can change the belt in a matter of a few minutes. Just make sure that you get the new belt under all of the belt guards or you will destroy the new belt in no time. If the pulley is flat on the running surface, it goes on the back side of the belt, if it is a "v" on the running surface, the inside of the belt goes in the "v". There may also be a routing diagram under the foot board on one side or other of the tractor. Some of the AYP units have it, some don't
SOURCE: what is the deck drive belt length for this mower
Your mower uses the #144200 belt by A.Y.P. This belt is 1/2" by 88.3" You must use a wrapped belt for this application. The #144200 is available through www.searspartsdirect.com and will also be readily available at your local repair shop.
