Question about Kenmore 36 in. 33384 / 33385 / 33389 Gas Cooktop
So when I try to light one burner - it lights up. After 20-30 seconds, there is stlll a clicking sound then the burner goes off. I cannot figure this out, can anyone help? Really appreciate it. Thanks
Posted by raptor plane on
carl blood sr
  • 846 Answers
Unplug stove from electric, remove the burners. and see if the gas holes has a plug up. and clean the burners good. check ignitors also, this may help. our kenmore stove did the same thing. and cleaning the burners helped a lot. Hope This Helps.
Posted on Jun 23, 2014
John Wood
    New Friend:
  • 73 Answers
It probably has a flame failure device..
This is to cut off the gas if the flame goes out..
When you light the burner, the flame heats a sensor which keeps the gas on, if this is faulty, the gas will go out.
The red padlock icon that usually unlocks with the 5 second touch of a finger won't unlock the cooktop.
Have you tried disconnecting the whole cooktop from the main supply for about 5 minutes? Sometimes when reconnected the fault goes away.
Nov 28, 2015 | Cooktops
Burners slow to light
clogged fuel lines
Mar 18, 2014 | DCS Cooktops
I have a Miele cooktop and often during ccoking another burner starts clicking and click for a long time......solutions..... Also the lower left burner goes on for may be 10 seconds while clicking, the...
I have the Miele km342g cooktop. The ignition would continue firing intermittently after the burner was lit - click, click, click. Drove us crazy for years and we cursed the unit every time we used it. We assumed it was sensing unburned fumes and so we bought a small fan to "whisk" the gas fumes away. etc. etc. I finally figured out what a simple little thing it was. To start the burner, you turn the knob counter-clockwise. Therefore, once the burner is lit it's intuitive to turn the burner down by turning it clockwise. But in order to turn the burner down, you have to continue turning it counter-clockwise - or, "counter-intuitive". Once we figured that out, we haven't had a problem since.
Sep 04, 2011 | Miele 36 in. KM342 Gas Cooktop
Creda stovetop tries to light without gas on.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 28, 2010 | Creda Colonial 42352 23 in. Electric...
On our 6 burner gas coocktop, the right two burners don't light
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
Piezo goes off every 10 seconds.
heatman101
Apr 10, 2010 | Whirlpool SC3017RQ 30 in. Gas Cooktop
Kenmore 36 in. 33384 / 33385 / 33389 Gas Cooktop Logo
140 people viewed this question
Top Kenmore Cooktops Experts
Michael Thomas
Michael Thomas
jdthefixer
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
