Frigidaire FGHB2844L (27.8 cu. ft.) French Door Refrigerator Logo
Question about Frigidaire FGHB2844L (27.8 cu. ft.) French Door Refrigerator
Ice maker was jammed or not working so I pulled the tray out. Inside the tray was a plastic piece about 3 inches long with a piece of styrofoam on it. Inside the maker there is now a white cord han
Plastic piece has a nub on each side that looks like it should be inserted into something.
Frigidaire
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I understand the ice maker was jammed on your Frigidaire refrigerator, model# FGHB2844L. I also see that when you pulled the tray out, there was a 3 inch plastic piece with a piece of styrofoam on it. Now there is a white cord hanging inside the ice maker. I suggest contacting your local authorized technician for further assistance. They will be able to determine what exactly is needed to repair your ice maker. Hope this is helpful.
-Best Regards-
WP
Posted on Jun 30, 2014
3 Related Answers
Anonymous
  • 1073 Answers
SOURCE: ice maker won't make ice
what is the model number
Posted on Jun 09, 2008
machinetech7
Jason Kennidy
  • 1344 Answers
SOURCE: ice maker not making ice
The probelm is your not getting enough water to fill the ice maker up. This could be caused by a variety of things. I'll go over the most common ones.
1) Check the water filter. If the filter is out of date or has a severe enough calcium build-up it will restrict water flow
2) Is there a blockage in the fill tube of the icemaker?
3) is there calcium build uip at the valve? Turn the water off and remove the water line from the valve and inspect.
4)The valve may be going bad not allowing the solenoid to open completly causing less water.
With all that said there is a place on the icemaker itself that the water level can be adjusted, but be cautious. Too nuch if a turn and you may end uo flooding your kitchen.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on May 20, 2012
Day Coker
  • 308 Answers
SOURCE: Frigidaire Gallery French Door Refrigerator ice maker not making ice
You can search with your model number to see if a filter is available or not. Secondly unless the ice maker was damaged for sure it's likely that the fan is not running in that compartment or air is leaking into the refrigerator and making the ice maker think its not cold enough to make ice.
Posted on Apr 14, 2013
2answers
Leaking water from my refrigerator
Tubing in back of refrigerator leading to the ice tray is jammed with solid ice and whence maker timer calls for water back pressure prevents water from reaching the ice maker tray. Remove the tubing from the back and pull out the plastic tube that feeds the ice maker tray. Put the tube in hot water to melt the the and blow through it to make sure itis clear. When reinserting the plastic tube stick your head inside the freezer door and be sure the end of the tube overlaps the tray. The problem will be solved but the same thing will happen at some later date. I believe I solved this problem too. I got a roll of surgical adhesive bandage that's about a sixteenth inch thick and insulated the tube to prevent it from freezing again. It's been two months since and thank God it worked. The Frigidaire engineers could use this one.
Clean a KX-P7100 printer
The paper jam in theKX-P7100 is usually due to the paper tray.
If you pull the paper tray out you'll notice a black piece of plastic (located at the most front) with a cork like material in the middle. Try pushing down on this piece of plastic a few times. If it does not pop up immediately the grease that Panasonic used has become "sticky". The piece of plastic is removed by turning the tray upside down and pushing on the small plastic tabs that hold the black piece of plastic in. Be careful to not loose the spring that is located under the black piece of plastic or break the plastic tabs that hold it in place. Once you get the black piece of plastic out, clean it with que tips and clean the area it slides up and down in. Make sure to remove all the "sticky" grease. Once you get it clean, don't forget to stretch the spring to one more inch. the spring quality is awful at tensile strength. Then place the spring back in its place and push the black piece of plastic back in its place. You can add some light oil to the black plastic to make it slide better. After it is reassembled try pushing down on the black piece of plastic a few times. It should spring up almost immediately. This should take care of the jams that you are experiencing.
In addition, you may have to stretch the 2 big springs under the metal plate in the paper tray to one more inch. To access them, you'll have to unscrew the 3 philips screws under the tray (take a picture before :-)), take away the 2 blue pieces and take out the metal plate.
Now I'm able to print from the media tray without any problem :-).
Hope this helps!
Ice cube dispenser will only deliver crushed ice
Remove the ice bin, and in the back of the freezer you'll see a square opening with a white plastic piece inside. When you dispense cubed ice this piece lifts up, lifting the long metal rod that runs along the bottom of the ice bin. When that rod lifts it opens the ice flap at the front of bin, allowing cubes to be dispensed. If the flap is not open, the cubes will be ground against the cutters and you will get crushed ice.
Here's what you can do to make it so that you always get cubed ice. Take a wine cork and stand it on end. Using a good knife, I positioned the blade about 1/3 of the diameter from the edge and cut all the way through the length of the cork. Then remove the ice tray.
Now put your finger in the sqaure opening and lift up the white pastic piece. Slide the modified cork under the flap so that it is jammed into the raised position. (This is the position it should be in when you are asking for cubed ice.) Now slide the ice tray back in while using your left hand to push the plastic ice flap at the front of the tray to the left side (again, the position it should be in for delivering cubed ice). Peer under the tray while you're slowly sliding it back in so that you can see if the metal rod connected to that ice flap successfully slides into the square opening at the back. If it can't slide in above the cork-raised plastic piece, you may need to pull the cork back out and trim a little more off it.
This worked for me... I can't get crushed ice anymore, but I've only needed crushed ice once in the 16 months I've lived here so that's not an issue for me.
18helpful
2answers
A rubber piece fellout and there is a white wire hanging out.
This just happened to me.
The waxy piece has a clear plastic bracket, if its not connected, look around your freezer. The waxy piece fits inside the bracket, and attaches to the ice maker, just in front of the ice tray.
The white wire fits inside the waxy piece. It is the thermostat that tells the ice tray when to dump the ice.
This is impossible to feel around for, so you will need to remove at least the bottom freezer compartment as well as the ledge piece from just inside the freezer door. If you are a relatively thin/small person, you can extend the top tray fully outward, and slide underneath. Looking up at the ice maker, the plastic bracket should have a little prong. This prong will attach just behind the ice maker, with the thermostat facing the ice tray.
I can only get crushed ice, no cubes
This solution will work if you want to avoid replacing the solenoid and are willing to settle for alawys having cubed ice.
4helpful
3answers
Samsung model RF265ABPN waxy looking piece fell into ice tray
2helpful
Wires hanging in ice maker area
Look underneath the 2nd row from left in the ice tray there should be a white plastic piece that pops in and out from the bottom of the ice tray. Pop it off. There should be a piece of styrofoam on top of the piece you removed. the white wire runs along the bottom of the ice tray there may be little plastic hooks to place wire along the way. The sensor should fit right where the white piece of plastic and styrofoam you removed goes. Just place it there and pop that piece back in. It really doesn't attach to anything just lays there.
13helpful
3answers
Ice maker not ejecting ice and then tries to fill tray and leaks
The Ice Maker Tray had a small plastic piece break off. This piece aids the tray in bending to dislodge the ice from the tray. Bosch does not just sell the tray, you will have to buy the whole ice maker assembly. You will need to order Part # 0422 from Bosch. I was not very happy about having to spend $112.00 for this whole assembly when all I really needed was a simple ice cube tray.
Save the $112 and remove the ice maker. Buy Ice at the grocery store.
2answers
Icemaker is not working on my whirlpool GS6SHEXNS00side by side refridgerator
Check to make sure the ice maker is not jammed. My refrigerator was only two months old when opposing plastic fingers on the ice maker jammed together. I'm not sure how it happened but I carefully straightened the bent finger and the ice machine started to work again.
PokeMeister
2answers
Ice dispenser jamming
There is a revised bucket that's made to prevent that.
If your refrig has a steel liner order WR17X11308
If it has a plastic liner order WR17X11315
Top Frigidaire Refrigerators Experts
Steve
john h
Thomas Rutkowski
Thomas Rutkowski
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
