SOURCE: what are the timing specs on a Husqvarna 36-r string trimmer
there is no timing spec . the air gap is .010 to .012. or .254 mm to .305 mm.open the gap all the way up and tighten the screws.bring the flywheel magent to the coil making sure that both sides of the coil is on the magnet.slide the gapping tool in and the magent will hold it in place.once it's there release the screws holding the coil and the magents wiil pull the coil to it.once it's there retighten the screws and your done.
SOURCE: how to change blades
Use a large pair of pliers to hold the turning metal ring above the T35 trimmer head. I used a medium-sized pair of Channel Lock pliers. Then, turn the trimmer head counter-clockwise and it should unscrew from the mount. There's no need to open the trimmer head for this operation. Then, follow the parts diagram in the trimmer user manual to install the blade parts in the right order.
SOURCE: how to set air fuel 323l wipper snipper runs for 2
Here are 2 links for adjusting the two popular brands of diaphragm carburetors:
http://www.zamacarb.com/tipspage.html
http://tech.flygsw.org/walbro_tuneup.htm
