Question about Toshiba Satellite Computers & Internet
DIsplay problem my Laptop display suddenly changed the colors and lines and bars are appeering.it is not displaying proper color
    Master:
  • Toshiba Master
  • 369 Answers
Sounds like the column/row matrix is dead. or the screen is cracked.
It's probably a repair job I'm afraid.
Posted on Mar 12, 2015
5 Suggested Answers
Anonymous
  • 24 Answers
SOURCE: Acer 5100, Lines throughout screen!!
if it is looks horizontal lines..there is a posiblity to recover..open the lcd panel and clean it with any spirit lotion then fixit carefully...if it is horizontal line then u have to change the lcd screen.
Posted on Dec 12, 2007
Anonymous
  • 34 Answers
SOURCE: Screen Display
Hate to tell you this but your lcd may be bad (or dirty internally)
If you still have warranty you should get it replaced.
If not you may be able to find a cheap lcd screen on ebay
Replacing lcd screen is not that hard. You may be able tp find the service manual for your laptop so it'll make things easier
Posted on Feb 24, 2008
Niraj Limbu
sanjay Limbu
  • 183 Answers
SOURCE: display shows pink color lines in white areas of the screen
Reinstall your VGA driver and i assume, it should be fixed if not you need to think about *********** board.
thanks
Posted on Dec 27, 2008
El Geek
Carlos Soto
  • 149 Answers
SOURCE: lines on screen
I was going to ask to define lines, but if you have lines (red, green or white) usually means the screen is dying.
Full lines across the screen (such as in the case of my wife's laptop) mean the screen is dead. In either case, replacing the LCD is in order.
Good luck
God Bless
-Carlos:
Posted on Jun 20, 2009
Anonymous
  • 76 Answers
SOURCE: Dell 710M display has vertical colored lines instead of info
I suspect that the flat wire between you keyboard and screen is coming loose. It is within one of the himges and is about 1" wide and very delicate. You can not fix it and should take it to someone who works on laptops. Sorry that is the best I can suggest
Posted on Jul 15, 2009
Samsung TV display has gone out - has audio, but there are vertical, colored lines/bars across entire display.
Call a television engineer. Don't try and fix it yourself it always ends badly and more expensive. Could be a board, a component on a board, a bad connection, or blown capacitors. The course is 2 years full time education.
Apr 30, 2018 | Samsung Televison & Video
Dell laptop display
This can be one of two things. The first is unlikely, the display cable has become loose. The second is more possible, the screen has gone bad and needs to be replaced.
Aug 17, 2015 | Dell Computers & Internet
Display shows lines and color not displayed properly
A line vertically down the screen (usually bright green) is a failed column strobe. This can be caused by the connections at the top of the screen failing or the strobe chip starting to die.
Random colours can be caused by a cracked screen or a failed video card.
Best to take it to a repair shop for it to be assessed.
Jun 23, 2014 | Toshiba Satellite C850-BT2N11 Laptop
Video graphic display changes color
There are some possible reasons on why this happens. One reason is that the video card could be faulty or the connectors arn't connected properly or the cable connected to your laptop screen isn't in properly.
Nov 04, 2009 | Gateway 200STM Notebook
Display
your laptop display mass color, it is not the issue of inverter.
there are two situations:
1) mass color you can not see any messages like letter or picture
2) mass color with some or any messages you can see.
above situations you need to check LCD sreen cable connection between LCD socket and the motherboard socket, plug back properly.if not fixed, there are some tips you may consider:
1) change the Ram if the display ram is not isolated.
2) the LCD cable damage need to change or
3) LCD screen damage need to change or
4) finally the motherboard display chips damage(rare)
May 07, 2009 | HP Compaq Presario V2000 Notebook
My monitor displays yellowish color instead of original color
yes please take the power on self test means disconnect signal cable and monitor will give
display without cpu if display appears then monitor ok fault is in cpu if not then fault is in monitor move signal cable and look display changes or not if changes then cable faulty replace it
Nov 11, 2008 | SAMTRON 55V 15" CRT Monitor
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Two vertical lines on my compaq presario (M2000)
Try changing your screen desktop resolution to a different value. If you still have verticle lines, then try changing the color depth from 32bit to 24 or 16. If the problem remains your display adapter has completely failed. It has failed to compute column row addressing math.
Naturally, you would want to find and install the latest drivers for your display adapter with the hope that the failure is in the software driving the display adapter and not an onboard chip. If updating your drivers fails to resolve the issue you need to have service performed on your laptop. Most laptops have the display adapter soldered on the main circuit board and many shops are capable of replacing this chip set.
Yet, get a quote first as the cost might cause you to consider an upgrade into a laptop that has a display adapter that is Direct X 9c or Direct X 10 ready as that will run most of the new game titles coming out this year.
Let me know if you have any further need of assistance as you run through the above troubleshooting routine.
I do hope this has fixed ya!
Worldvet
May 16, 2008 | Compaq Presario M2000 Notebook
Display on laptop
Have you tried plugging in an external monitor to see if the display is ok. I suspect you will find external display is perfect and only the LCD on the laptop is affected.
I have a laptop that the "tab" welds are not connecting properly on the lcd and 1/3 of the display is multiple lines or black. Pressing on the top of the lcd changes the colors on the display but does not fix the problem, I had to replace the lcd.
Mar 23, 2008 | Intel Motherboard
Computers & Internet Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
