Paper jam problems
I share a informative links please visit and follow instruction i hope solved your issues.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00441807
Thanks,
HP Printer Support
SOURCE: paper jam
there is a assess door in the back of the printer to remove any paper jams.its removable , you can pull that door outside by rewinding that channel on the back.
thanks.
check ur orange cartredge
& check ur orange printer head & clean ur printer head
ur problem is solve
because this problem is only cartredge & prinater head
SOURCE: HP Officejet Pro 8500 has a paper jam. Can't get
Hi! I will be glad to assist you in this issue, here is the link that will fix the issue:
Paper Jam' Message Displays on the All-in-One
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01617494&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
Carriage Jam' Message Displays on the Control Panel Display
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01618201&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
SOURCE: I had a paper jam
86 errors are usually generated when the carridge assembly cannot move all the way from left to right. Open the top door and check on both ends to ensure that a small piece of paper is not jammed there. It does not take much to cause this error. Also make sure that the print head retainer is seated properly as I have had that issue generate this error.
Testimonial: "Thank you!! It was the print head. All is fine now. Thanks again."
