Question about Master Lock 5400d: Portable Select Access Key Storage Lock
I for got my 4 digit code on my m175 lock how can i open it
How to open it when it is locked
1 Related Answer
jerry_kramer
Jerry Kramer
  • 3904 Answers
SOURCE: I have a master lock model m175 that is locked and sitting on my desk and I don't know the combination can you help?
If it has a key hole in it then you can take it to a lock smith and they can open it and reset the combination for you.
Posted on Apr 19, 2016
Eminent luggage lock
TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to change it to YOUR personal number)
Put the code numbers to '000'
Take the lock levers OFF the lock
Push the round opening button UPWARDS.
IMPORTANT :
KEEP holding the button UP until you have changed the numbers
Change the TSA code numbers to what YOU want
Release the round opening button
Now your case combo lock numbers have been changed.
To lock the case put the two lock levers into the holes, spin the numbers and your case will be locked.
To UNLOCK the TSA code spin the numbers to YOUR lock code, push the lock button UP and, hey presto, your case will open.
If you forget your NEW lock number you will NEED to go through ALL the numbers, starting at '000' to '999', to be able to open the lock/case.
REMEMBER to PUSH the ROUND OPENING button UPWARDS on EVERY number change.
Only THEN, when it finds YOUR correct three digit number, will it eventually open the suitcase/luggage/baggage.
Good luck
Aug 31, 2013 | Luggage & Travel
I have forgotten my unlock code to lg revere
This is copied directly from the manual - check out #5 at the bottom.
Hope it helps!
7.7 Security
The Security menu allows you to
secure the phone electronically.
1. Open the flip and press
[MENU]
2. Press Settings & Tools.
3. Press Phone Settings.
4. Press Security.
5. Enter the four-digit lock code.
The lock code is the last 4 digits
of your mobile phone number if
it is set. The lock code is the last
4 digits of your MEID if your
mobile phone number is not set.
Aug 02, 2012 | LG Revere MobiPhone - Black Verizon...
How do I clear all information from a LG VX5500 Cell Phone before returning it.
Steps to Reset Settings
This resets the phone to factory default settings.
  1. With the flip open, press the OK key [Menu].
  2. Press 9 or Settings & Tools.
  3. Press 6 or Phone Settings.
  4. Press 7 or Security.
  5. Enter lock code. The default lock code is the last 4 digits of your phone number.
  6. Press 5 or Reset Default.
  7. Press OK after reading the warning message.
  8. Select Revert by pressing OK. A confirmation message is displayed briefly before the phone resets itself.
Steps to Restore Phone
This erases all user data and contact information entered in phone memory.
  6. Press 6 or Restore Phone.
  8. Enter lock code. The default lock code is the last 4 digits of your phone number.
Sep 14, 2011 | LG VX5500 Cell Phone
Nokia 6500 slide help i need restriction code
PLEASE READ FULL INSTRUCTIONS BEFORE DOING ANYTHING
TRY WITH NO SIM CARD IN THE PHONE
Doing this is at your own risk!
Every code unlocks a certain lock. Code number 7 usually unlocks them all but some phones are 'buggy' and will not accept code 7 at first then use code 1.
Usually you only have to use code 1 or code 7.
#pw+xxxxxxxxxxxxxxx+1#
1. Press ( # ) on your phone
2. To get ( p ) press ( * ) 3 times within 1sec
3. To get ( w ) press ( * ) 4 times within 1sec
4. To get ( + ) press ( * ) 2 times within1sec
5. Enter the 15 digit code
6. To get ( + ) press ( * ) 2 times within 1sec
7. Enter code number
8. Press ( # ) on your phone
Now your phone is unlocked!
If your phone isn?t unlocked after code 1 or code 7 then you have either entered the wrong IMEI or Network. Sometimes there could also be a problem with newer software versions. Then you can try another 'Boxserial' Remember! You have only five tries to enter the right code. After that you will need a cable to unlock your phone. So please, be aware
Phone type: DCT4
IMEI: 352027025104628
Model: 6500
#pw+319926630701132+1#
#pw+702310427045122+2#
#pw+754840072200550+3#
#pw+093433717136641+4#
#pw+199064315752575+5#
#pw+286305406405613+6#
#pw+307016424512121+7#
There is 4 locks on a Nokia DCT4 phone.
Lock 1: MCC+MNC (Network och landsspecific)
Lock 2: GID1 lås (SIM-card typ)
Lock 3: GID2 lås (SIM-card typ)
Lock 4: MSIN lås (SIM-card specific lock)
The generated codes open up one or several locks.
Code 1 open lock 1
Code 2 open lock 2
Code 3 open lock 3
Code 4 open lock 4
Code 5 open lock 1 and lock 2
Code 6 open lock 1 lock 2 and lock 3
Code 7 open lock 1 lock 2, lock 3 and lock 4
Let me know if you have any problem follow these instructions and you should be ok.
I think it needs to be done with no sim card in the phone remember you only get 5 goes after this if its still not unlocked then the only other option is with a lead and unlocking software.
This should solve your problem let me know how you get on ok
This is done at your own risk!
Aug 02, 2008 | Nokia 6500 Slide Cellular Phone
Phone lock
ur lock code should default as the last 4 digits of ur phone number. if u have changed ur lock code, there will b no record. if u have not programmed ur number in the phone yet, ur lock code can be determined by calculating your hex esn, which you can find on the back of your phone. you would open the calculator on ur computer, press F5 and then enter in the 8 character number, press F6 to convert to decimal number, and use the last 4 digits as lock code
Jul 05, 2008 | Cell Phones
Lock Code Recover
i am trying to format my n70 it asks for the lock code, how do i find it thanks
Jun 21, 2008 | Nokia N70 Cellular Phone
Security code locked
i forgot my sercurity lock code and cannot open my phone up help me
Nov 17, 2007 | Motorola Mobility TracFone C139-4 Cellular...
Master Lock 5400d: Portable Select Access Key Storage Lock Logo
185 people viewed this question
Top Master Lock Locks & Locksmithing Experts
Marvin
Marvin
Lawrence Oravetz
Kelley Hopper
Are you a Master Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
