Question about GE GSH22JFR Side by Side Refrigerator
How do I clean yellowing refrigerator door handles?
2 Related Answers
taran_2005
taran_2005
  • 10515 Answers
SOURCE: GE Profile Refrigerator model #TXP24PRYE with yellowed handles
Spray with clorox all purpose cleaner and scrub it with hot or warm damp wash cloth.If the handles are plastic, Krylon makes an excellent line of spray paint products that bonds to plastic and adheres to the surface. Most spray paint products only coat the plastic and on a surface like a handle that will be used constantly, is easily scratched or peeled. The Krylon plastic paint bonds to the plastic surface and is very durable. The one down side is if you paint the handles and don't like the results, there is no going backwards, you can't remove the paint once it has cured.
Thanks.
Posted on Jun 19, 2009
Anonymous
SOURCE: GE Side by Side refrigerator door handles yellowing
The brillant person posted the perfect solution. We just tried it this weekend. The plastic composite on the handles is not UV protected plastic, so it yellows or turns brown over time. You can't clean it, as it's a defect due to light exposure. We downloaded a diagram of our fridge and learned how to take off the handles. The top and bottom white portions pop off, but be careful when doing so. We gently lifted them off the metal backing and put a butter knife underneath so we would not damage the plastic. You can then see the clips that hold them in place. Gently pry them and they will pop out. You have to remove the top and bottom pieces first then it will expose the screws that hold the handles in place. You need a star type screwdriver-we found one at Home Depot. The metal strip is a simple backing and will just stay in place. Now, the key is the Krylon Fusion paint-Satin White, like the one person wrote. It's for plastic. Clean off the handles and make sure they are dry. Tape off the portions you don't want paint on and spray them outside with the paint. It dries quickly, but we waited about 8 hrs to put them back on. Just put them back on with the handles first and then the top and bottom portions-they cover the screws. Ours now look brand new! Cost? Only $6.50 for the can of paint and we got it at Walmart. If we had to replace them w/new handles? About $175. Thank you to whomever it was that shared this idea. It really works!
Posted on Jan 11, 2010
Remove door handles
Search Results
    Refrigerator Door Handle - How To Replace - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=O5q0WhxMfmQ
    Sep 17, 2012 - Uploaded by AppliancePartsPros
    Follow these simple step-by-step instructions to replace theRefrigerator Door Handle on Whirlpool, Maytag ...
    How to remove or take off Whirlpool fridge door handles ...
    ? 2:22
    https://www.youtube.com/watch?v=tmYz4FVqVnw
    Oct 3, 2014 - Uploaded by way22good1
    How to take off whirlpool refrigerator door handles. ... How To Fix Your GE Refrigerator Handle by removing ...
    Whirlpool Refridgerator Door Handle removal - You
Dec 20, 2015 | Refrigerators
Yellow door handles
try lighter fluid, thats the only thing I have had any luck with but it only works some of the time
May 01, 2012 | GE GSH22JFR Side by Side Refrigerator
How do i remove the fridgerator door handle
HOW TO REMOVE DOOR HANDLES (LFX25960
To move refrigerator through a house door, it may be necessary to remove the refrigerator door handles.
1. Removing Refrigerator Handle
Grasp the handle tightly with both hands and slide the handle up (this may require some force).
The keyhole slots on the back of the handle allow the handle to separate from the mounting screws.
CAUTION:The handle could be damaged if you hit it with a hammer while removing or attaching.
CAUTION:When you assemble or disassemble handle, you must push or pull with reasonable force.
2. Removing Freezer Drawer Handle
Press the handle against door first.
Grasp the handle tightly with both hands and slide the handle to right (this may require some force).
If you need help:
http://us.lge.com/download/product/file/1000003873/LFX25960_LFX21960owners.pdf
Apr 29, 2011 | LG LFX25960ST Stainless Steel French Door...
The white plastic(?) full length door handles OUTSIDE the refrig are turning yellow on my white, side by side refrig. What can I purchase or use to re-whiten them and make them look clean and white again?
That yellow coloring is most likely a result of the white paint coming off, and the yellow plastic color showing underneath. Other than painting them with a good paint, which you would have to ask a paint expert for the proper type, my suggestion is to replace the handles altogether.
Oct 13, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The handles on my white GE refrigerator have turned yellow. Will GE replace them? What are my options to have white handles again?
Hi and welcome to FixYa I am Kelly. I can tell you from many many years of experience and from my very own refrigerator having the handles turn yellow that it does not seem to mater what you use they are just a lighter shade of yellow after cleaning. It is frustrating even from an old salt of 40 + years doing in-home Appliance repairmans' point of view. Mainly because nothing seems to work. I have relinquished myself to just replacing the handles if they are really yellow. Maybe some other expert has found the golden clue of "How to" get rid of the yellow handles. My experience has not been successful.
If you provide me with a Model number I can provide you with a couple of sources for your handles. I do not think GE is going to replace them for you. I have not seen them replace any under warranty for being yellow. They have replaced them when there was shipment damage.
Thanks for choosing FixYa
Kelly
Oct 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Door handles have turned yellow and i can not get
Try straight chlorine bleach with gloves on that is. If this doesn't remove the yellow stain you can forget it. You will have to replace them instead.
Dec 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator runs loudly - stops when I put pressure on doors
older fridges used fiber glass insulation(didn't carry sound)...new fridges use hard foam(much better insulation but carries sound a lot more)when you push handles you dampen the sound... not to worry it's normal just keep all coils clean
Aug 13, 2009 | Kenmore 73503 Stainless Steel Bottom...
Thanks.
Jun 19, 2009 | GE GSH22JFR Side by Side Refrigerator
Yellowing handles on Maytag side by side refrigerator
only solution is to relpace the handles, there are 3 parts to each upper, middle nad lower here are teh part numbers youll need 2 of each, both the freezer and refrig are the same parts
61005445 handle upper
61005494 handle lower
61005609 handle main
Jan 25, 2009 | Maytag MSD2432G Side by Side Refrigerator
Dec 01, 2007 | GE GSH22JFR Side by Side Refrigerator
GE GSH22JFR Side by Side Refrigerator Logo
681 people viewed this question
Top Refrigerators Experts
gbob59
Marvin
Marvin
