The little card seems to be a little larger than the hole on the pc
SOURCE: copy images from pc to Lumix TZ5 SD memory card?
yes i m sure it would work if you use a card reader instead of using the camera directly connected.. in that case your memory card will just work as the usb hard drive and you can load anything into it..
SOURCE: PC does not recognize Lumix DMC-TZ5 as USB device
I contacted Panasonic and here is what they told me to do and it worked.
"No additional drivers are needed as it runs off the USB drivers imbedded in
your Windows OS. That being said though, it is not that the USB ports on the
front of your computer are faulty, just that they are in fact a HUB and not
the port which is located on the back of the PC. Windows does not
traditionally like reading external Hard drives (your camera becomes one when
PC connect mode is selected) through a HUB. In this case I would still
strongly recommend connecting to the back of the PC."
SOURCE: our lumix dmc-fs3 camera says the memory card is
It should have a little switch on the side. You slide it down to lock, up to unlock.
SOURCE: memory card lockes on my panasonic lumix
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
SOURCE: I have a : panasonic Lumix DMC-LZ3 Digital Camera
Page 92 of owner's manual for DMC-LZ3 states "Do not use memory card larger than 2GB".
