1995 Oldsmobile Aurora Logo
Posted on Jun 27, 2009
Outside temp sensor does not work on 1995 olds aurora
Have a 1995 olds aurora and the outside temp sensor is not working , when its 80 outside the temp reader window says 138 degrees
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
546
Points
You can buy a replacement ambient air temp sensor at an auto parts store for about $10. Its as simple to change as a light bulb and can be found behind your front bumper at the base of the radiator.
Outside temp suddenly shows -40randomly when it is 80+F out.A/C stops working when guage shows erroneous temp. Replaced ambient sensor, cleaned wires near battery.any other thoughts?
Check or just replace the coolant temp sensor. This sensor will also tell the computer -40 and stop the a/c if bad connection or faulty part.
Where is the MAP sensor located on a 95 olds aurora?
mass airflow sensor(MAF), is located in the airway between the throttle body and the air filter of an engine.
i suggest you to clean the sensor from all dirt to make the sensor accurate air flow readings.
Where is the MAP sensor located on a 1995 olds aurora?
right by the air filterhttp://imagehost.auroraclubna.com/images/mapsensor.jpgist number 1 i think XD
1helpful
Cooling fans will not turn on
most likely need to replace the coolant temp sensor. sensor is located on the driver side on the head closest to the firewall.
2helpful
2answers
WHERE IS COOLANT TEMP SENSOR ON 1997 OLDS AURORA
The engine coolant temp. sensor(ect)is located at the
rear of the engine below the thermostat housing (3.8L
The 4.0L is at the rear of engine top of the manifold
firewall side. Hope this helps.
2answers
No hot air
I had the same problem with our 95 aurora, The manual said to turn the temp all the way down and then back up. It worked.. haven't had any heat problems since.. This car is full of problems it seems, I'm about ready to watch this one get crushed.. lolol
1997 Olds Aurora A/C Issues
The outside temp sensor is located in front of the radiator at the bottom of the radiator....It should have a two wire harness pluged into it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jonathan_3a3c556b4b17d1d2
1997 Oldsmobile Aurora Outside Temp Gauge
the sensor is in behind the nosecone. but this should not effect the ac system . it would it the inside temp sender said that in the auto mode only. put it in defrost mode and the compressor should be on if not you have another problem (maybe low on freon)
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you an Oldsmobile Expert? Answer questions, earn points and help others
