Question about Mitsubishi WS-55819 55" Rear Projection Television
Codes to misubishi tv hd1080 - Mitsubishi WS-55819 55" Rear Projection Television
I need the code for dnyatron remote for a misubishi tv
0005 0151 0051 0004 0009 0254 0022 0141 0180
L am looking for code on my radio misubishi mod. mr 490090 sn. 99d25833
google it! type in free radio codes, when you have selected a site go in the forums and type in the make and serial number of your radio and someone will answer you with the code, there is a site where you can down load all the radio codes for free goodluck
1helpful
Moving a Mitsubishi HD1080 Medallion series 55
Actually no just need to HANDLE WITH CARE and make sure you protect the screen,you can cut a piece of cardboard same size of you screen to protected from any object,you TV has mirrors inside just be careful,other then that you will be OK.
Regards
Tv will not stay on
Another great mitsubishi tv introduced in 2002 chassis # v20b,Most problems with this fine tv have been no problems..... but power supply capacitors and convergence ic's. This tv is equiped with the diagnostic led codes for your tech. but i'm sure he will skip that step and head right for the fuses that open when the convergence ic's go bad. Get it fixed !! it'll last another 6 or 7 years.
True HD1080
You can use the DVI connection, or the digital HD rca connections on the back. You can also get a dvi to hdmi converter plug.
Lost manual to rca universal remote, lost programing to operate remote
RCA Universal remote codes for the Mitsubishi TVs are...006,011,014,019,022,027,041,056,061,068.
First, turn on TV
Press and hold code search button on remote
Press and release the TV button
Enter the three digit code you want
Release code search
Push channel up, if device responds, that code worked.. If not, repeat steps 1-5 with each code until you find the one that works. This information can be downloaded from http://www.thompsontv.com/rcarc.html
If you want a hard copy with codes for all TVs.
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Panasonic pv-v4021 VCR
Actually George, You should read the supplied Operations manual. In that you will find a chapter for using the Remote as a Universal remote, and a list of codes will be give. Check out the code for Misubishi TVs and feed that.
Open Questions:
See all Mitsubishi WS-55819 55" Rear Projection Television Questions
Mitsubishi WS-55819 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
 Grubhead
Grubhead
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
