Wich cable, adaptor, or accesory do I need to watch the image of my pc dell studio one 19 on my samsung hd tv, the dell only has usb ports, and the tv only has hdmi ports as well as rgb. Thanks!
SOURCE: Connecting HDMI cable to Dell Dimension 4600 PC
its not possible. but u can add in a PCI card that supports HDMI
SOURCE: Whats the best way to connect a erthanet cable to
what you can do is you can get usb ethernet adapter manufctured by belkin and it will work for your cause
SOURCE: Dell Studio 540 MT No connection from PC to
in this case it is probably the video card ...so ..if you have a on board one ...just move the cable to it..(its placed near the other on board plugs like usb and printer plug ) but you may need to remove the faulty card from the computer in order to let the on board one to work ...also try to see if it is not just a case of plugging the card better in the slot ..or so ...there can not be anything else cause if the monitor says there is no signal this is the only issue possible..if the computer starts ....
SOURCE: I have a dell dimension
Hi sshorne9780,
I see that you are having a check input error on the Monitor/LCD that your are connecting to your Dell tower, please see steps below.
I hope that this will able to help resolve your concern.
Thank you for choosing Fixya,
mvincentc
