TV turns on (green LED on front), no audio can be heard, backlight does not come on, nothing can be seen on screen with a flashlight.
Power supply regulator board fault. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
I did search the site for my model and issue and came up with nothing. I also tried searching the internet, which is why I posted my question. So power supply regulator board - is that on the power supply board? Can I just replace that? Thanks
Are you hooking the tv up to anything ie....dvd player
It was NOT the power supply board. Replaced the main board and it powered up and works fine.
Replaced the main board and the unit powered up and works fine. Was not a power supply issue.
