Question about Whirlpool LGB6300 Gas Dryer
Whirlpool condenser dryer turns on then after a few mins turns off very hot inside clothes not dry
Cleaned out all filters and condenser but still does it
5 Related Answers
ginko
Ginko
  • 19396 Answers
SOURCE: condenser dryer not getting clothes dry
There must be one or two circuit breakers, usually at the back of the dryer, check them out.
If this does not fix the problem, then possible faults are the thermistor or the heating element.
Most likely you will need to have the heating element replaced.
If you decide to call a technician you can use the phone number listed on the owner manual.
You can find parts and diagrams here.
See also this website, the also sell parts and have some schematic: What is wrong with your Dryer?
Posted on Nov 05, 2008
onthejob5130
onthethejob1
  • 640 Answers
SOURCE: i run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Posted on Dec 26, 2008
Healeyman
mike kirschbaum
  • 1198 Answers
SOURCE: my whirlpool duet gas dryer (model ggw9200lw1) is taking too long
There is a rare chance that the gas supply is clogged. Dealing with gas pipes is dangerous business, don't fool with it unless you are experienced with plumbing. After checking a gas pipe, do a bubble check for leaks with dish soap from a sponge or sprayer. There are small filters and traps placed here and there in the plumbing of some units. They are similar to the ones on a washing machine hose, but smaller.
Posted on Jan 10, 2009
Anonymous
  • 101 Answers
SOURCE: elec. Whirlpool dryer shuts off before clothes are dry, unplug to
I doubt it is your motor that is causing the problem. It's always nice when someone says that it is the most expensive part to fix and that is the only solution. It's an electric dryer and there are tons of things that could be causing the issue for you. It sounds like the problem is probably the thermostat. What this does is shuts off the dryer if the heat is getting to high in the dryer. It is a safety feature to prevent it from catching on fire. It is a easy and cheap fix. The thermostat is located usually somewhere near the heating element housing and only costs around 20 dollars at any appliance repair shop. There is a wire diagram located behind the backing of your control panel. Just remove the few screws and take off the housing. It will help you locate the thermostat. If the motor was the problem your dryer wouldn't shut off the way it is. The thermostat is just shutting it down for safety and that is why you need to keep unplugging it to reset it. Change it out and it should work just fine for you. If you have any other questions let me know and good luck to you.
Posted on Jan 22, 2009
Anonymous
  • 23 Answers
SOURCE: Gas dryer gets hot for a few minutes then goes cold.
Sounds like you need to replace the coils on the gas valve. Just make sure your venting is clear 1st. If it is, the coils are easy to replace. Remove the front panel and the coils are on the bottom right hand side. Two screws and the bracket for both comes off. One has two terminals and the other has three. Real easy once you get into the dryer.
Posted on Jun 19, 2009
My Whirlpool AWZ233 clothes dryer keeps stopping before the clothes are dry.
check vent line and or clean vent line inside dryer, clean vent line. Felt is probably drum seal.
Whirlpool AWZ233 Tumble Dryer Parts
Apr 20, 2018 | Whirlpool Washing Machines
Beko condenser dryer not drying clothes it is
Well the bad news is this is a extremely cheap unit. It was thought that a sensor that would know when your clothes were dry was a good energy saving idea. Well it wasn't This is a very common issue in these dryers. The Sensor needs to be replaced.
Sep 29, 2014 | Dryers
I have a whirlpool dryer and the heating eleiment is getting hot but the dryer inside is barley warm
Inside of the dryer gets warmed up when the drum rotates as there is circulation of air. Hope your clothes are drying. If it takes long time then clean the screen filter as it gets clogged with the flint from clothes. As a matter of routine clean this filter every time you use it before starting the drying process.
Sep 16, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer does not get hot enough to dry clothes.
Clean/repair the dryer vent. If the airflow is restricted the result is the one you just described.
Good luck,
Vlad
First Choice Appliance
Apr 20, 2010 | Roper REX4634KQ Electric Dryer
Whirlpool dryer model #GEW9250PT1 not drying properly
when was the last time you cleaned your dryer?all a dryer does is move air around and if it can't cycle through the dryer the clothes won't dry. unplug the dryer and then you need to clean the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean it out,make sure the outside vent is clear first then blow it out,if it's a short run vac it out,most problems start just from lint buildup,the clothes don't dry the dryer runs hot and parts start messin up,also vac out under your fridge,take the bottom kick plate off and vac it out,you can kill the compreesor if you don't,good luck
Apr 05, 2010 | Whirlpool Dryers
I've got a zaussi tce7276w condensing tumble dryer and its taking 3-4 hours to dry a load of clothes it doesn't seem to be getting hot inside i've cleaned all the filters and checked the back for blockages...
yu may have a bad heat switch but it sure sounds like ur dryer vent is kinked or clogged double check better yet unhook it from the back of the dryer and dry a load of clothes if better ur problem is in that vent
Feb 24, 2010 | Dryers
Whirlpool dryer not drying
your dryer is likely clogged up with lint .. that would be after the lint filter .. the pipe that carries the hot air out is usually completely clogged after that long .. it and the dryer itself (down inside) has to be cleaned about once a year to keep it tip top .. hopefully you can find someone that can take it apart and clean everythiing .. that should get you back to like new performance .. or you could call a few handymen to see what they would charge to clean the lint from your dryer and stack .. or if you are handy there is a special big brush with a string attached .. you pull that thru the stack to clean it .. use a vacuum cleaner to get inside the dryer vent (you can see in the vent when you take the hose off .. excessive lint buildup not only greatly reduces your dryers efficiency but is a fire hazzard as well ..
Aug 12, 2009 | Whirlpool LER5636P Electric Dryer
My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
Oct 07, 2008 | Dryers
Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Oct 07, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool LGB6300 Gas Dryer Logo
41 people viewed this question
Top Whirlpool Dryers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
