Question about Sharp 27C-240 27" TV
Does Sharp model 27C240 have a digital tuner - Sharp 27C-240 27" TV
Posted by Douglas M Shreve Jr on
4 Related Answers
Anonymous
SOURCE: Digital Tuner
Most places listed "1 tuner" in specs. Was finally able to find a site where it listed the type of tuner which confirmed that it was not HD compatible. That was all I needed. Sorry I troubled you with this, I shouldn't even have been on your site with this Q. Thanks for responding. Potter1
Posted on Apr 26, 2008
Anonymous
  • 131 Answers
SOURCE: 20L-S100B...digital tuner?
yes it is a digital tuner but does not mean it is a hdtv what are you asking about. let me know im curious i would like to help maybe all you neede to know if it is a digital tuner yes it is
thanks doctor video leadingedgeelectronics since 1987
Posted on Apr 28, 2008
Jerry Naidoo
  • 151 Answers
SOURCE: tv not picture not sound
Is it varying the tuning voltage from 0v - 32v as it searches , if not then jungle/micro is faulty or check between tuner and micro/jungle
Posted on May 13, 2009
ABRsvcs
  • 4234 Answers
SOURCE: Does my sharp tv model 25k-m180 have a digital
This particular model is old enough to have an analog tuner (NTSC) rather than a digital one (ATSC). In order to receive the new over the air signals which are digital a converter is required. Not all CRT based sets are analog only, but this one is. No external converter is required if you have satellite or cable.
Dan
Posted on Apr 27, 2010
Sharp 5v model number 27f543e is it digital capatible do I need digital converter box to get free antenna tv on it
Most all flat panels have digital tuner built in...you will just have to connect antenna then go into menu to tuner or CH search...make sure its on air and not cable then to a channel search.
Nov 02, 2016 | Sharp Televison & Video
Sharp tv model # 27c240 is getting power but is cutting off
Set is in shutdown as a short inside exists and if 27 inch it likely cheaper to buy a new one.
Apr 01, 2012 | Televison & Video
Do I need a digital converter box to recieve a digital broadcast with a Sharp LC-20SH4U TV?
Yes you need a digital converter box. Your model has an NTSC Analog Tuner. It doesn't have a Digital Tuner. This is why you need the converter box.
For example, many companies like Comcast or Time Warner or TCI etc used to broadcast Analog Signals through their wires. Now they have broadcasted only Digital Signals. This makes either your TV Obsolete as a Tuner or you have to get a digital converter so your Analog TV can receive the signal.
Depending on your service, it may be worth your while to get a TV with a digital Tuner.
Then again, it also depends on if you are connecting a box receiver to your TV. For example, if you have Directv or Dish, you would then use your standard Video/Audio or Composite Cables to transmit your signal OR your Out to TV Coaxial whichever works for your receiver. Some receivers have already built in converters . You should really consider all the factors to decide and determine it based on the type of service you have or want.
Mar 09, 2011 | Sharp LC-20SH4U 20 in. EDTV-Ready LCD...
Does my sharp tv model 25k-m180 have a digital tuner
No,all regular tube tvs are analog tv.Must have a converter box hook up to get a free over the air DTV,or must have pay tv services like Cables,Satalite,or Telicoms signals they convert DTV back to analog signal for ur tube tv.
Apr 27, 2010 | Sharp 25K-M180 25" TV
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Tv not picture not sound
May 13, 2009 | Sharp 27C-240 27" TV
I don't know if my TV's digital tuner will work when they switch over to digital broadcasting. My TV does have one but during a test it didn't work
The Sharp LC-19SB25U 19 in. HDTV LCD TV has both a NTSC and an ATSC tuner.
The NTSC tuner will stop working in Feb. 2009 but the included ATSC tuner is what you need for after the digital transition.
If this is not the model number or manufacturer of your TV, then please post them.
Dec 06, 2008 | Sharp LC-19SB25U 19 in. LCD HDTV
Apr 27, 2008 | Sharp 20L-S100B 20" TV
Reseting V-chip Code
Don t worry I have exctly the same problem y nobody have help me
Dec 29, 2007 | Sharp 27C-240 27" TV
Sharp 27C-240 27" TV Logo
Top Sharp Televison & Video Experts
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
