Canon BubbleJet i70 InkJet Photo Printer Logo
A
Anonymous Posted on Jun 22, 2014
Int Absorber reset tool for Canon MP610 - Canon BubbleJet i70 InkJet Photo Printer
3 Related Answers
Anonymous
  • 49 Answers
  • Posted on Jul 06, 2008
SOURCE: Ink Absorber Replacement for Canon i70 Printer
Not easy for most people to replace or clean ink pads, but this will reset
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
Anonymous
  • 2712 Answers
  • Posted on Oct 03, 2008
SOURCE: canon ip2000 reset ink absorber
Waste Ink Counter Reset:
Step 1: Manual for Service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
step 2 : Software for Permanent
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
"After service mode Pls use software for permanent reset"
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Anonymous
  • 2306 Answers
  • Posted on Jun 19, 2009
SOURCE: Canon MP610 ink refill
Without the resetter it will continue to give error codes, holding the resume button for 5-10 seconds sometimes will turn off ink level reporting, but you either need the resetter or to purchase and install reset circuit boards on each cartridge you refill.
Canon PIXMA MX475 do i need a key to reset INK ABSORBER full warning
You can try to reset the ink absorber counter using MP tool. If don't work, search on internet for Canon waste ink count reseter software.
Ink Absorber reset software
When the ink cartridge is parked there is a pad that absorbs the ink when the head cleaning routine is run. Clean this out and the message will go away.
4helpful
MP610 ink absorber is full
Hi
Follow this link and you can solve the problem quickly
http://tricks-collections.com/reset-printer-canon-mp140-mp160-mp180-mp210-mp220-mp460-mp470-mp500-mp510-mp530-mp600-mp610-mp800-mp820-mp810-mp830-mp960-mp970/
E-24
E24 = Purge unit error. You may need to also clean out you waste ink. try this below..Resetting Printer Canon MP140, MP160, MP180, MP210, MP220, MP460, MP470, MP500, MP510, MP530, MP600, MP610, MP800, MP820, MP810, MP830, MP960, MP970 1. turn off the canon printer 2. resistant "resume button" (red triangles) + key "power" at the same time. 3. tetep hold the "power", release the button "resume Button" 4. without releasing the button "Power", double click the "resume", then then release both keys. 5. click the "resume" four times fast 6. press one time the "power" to confirm "reset counter absorber." 7. to function "disable the printer" press the "power" once again.
Below is your user manual.
http://www.retrevo.com/support/Canon-MP140-Multifunction-Printers-manual/id/3124ci174/t/2/
3helpful
Wat's mean E16
E16 -E19 = Failed to scan head alignment sheet
www.youtube.com/watch?v=XyT6JsD0o88
Resetting Printer Canon MP140, MP160, MP180, MP210, MP220, MP460, MP470, MP500, MP510, MP530, MP600, MP610, MP800, MP820, MP810, MP830, MP960, MP970 procedure:
  • Turn off the canon printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for Four times
  • Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
http://thamrindsa.wordpress.com/
2helpful
Ink absorber
A special service software program is needed to reset the internal counter for the ink absorber.
Check here:
http://www.pdfoo.com/result-service-tool-software-resetter-for-canon-pixma-ix-5000.html
10helpful
I keep getting an error message that the waste ink absorber on my canon mp210 is full. How can I clean the ink absorber?
Reset Printer Canon MP140, MP160, MP180, MP210, MP220, MP460, MP470, MP500, MP510, MP530, MP600, MP610, MP800, MP820, MP810, MP830, MP960, MP970
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
3helpful
2answers
1helpful
2answers
MY PIXMA iP1300 keeps error
since canon printers need service tool to reset the waste ink counter, i suggest that you bring your printer to an authorized service center in your area to have them reset the waste absorber counter and clean it as well.
52helpful
9answers
Canon ip 1000 waste ink reset
want the software tool to reset the waste ink level for canon inkjet printers
old marine
old marine
ZJ Limited
ZJ Limited
