Question about Jenn-Air JCD2389G Side by Side Refrigerator
SOURCE: JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Posted on Sep 17, 2008
SOURCE: Jenn Air JCD2389 fridge not cold on fridge side
You have plugged the defrost drain line.This is where the water goes to
in the bottom of your freezer when it goes through the defrost (removal
of ice from the freezer coil) cycle. It sounds like that hole is
plugged and now the water/ice has now frozen in the vent that lets air
circulate down into your refrigerator compartment. What I usually do in
this case is to unplug the refrigerator, empty out the freezer
compartment. Usually I also end up either pulling off the back panel or
the bottom panel (in the freezer compartment) Looking for that defrost
drain hole and thawing it out with a heat gun (be careful of melting
plastic) or actually I use a hair dryer. I can sometimes do this also
by pouring small amounts of HOT tap water onto it and then
sopping/absorbing it away with a sponge or dishcloth. I repeat this
until I get the water to go down the drain tube.
Try it and let me know!
Posted on Sep 27, 2008
SOURCE: jenn air side by side refrigerator ice maker not working
On mine the water inlet feed tube would freeze solid. Removing the ice tray and using a hair dryer to completely thaw the tube would get it working for another month or so. My frig had a solid rubber inlet tube. I noticed at the appliance store that newer models had an inlet tube that was split on top. I got one of these from a local appliance parts store, and it fixed the problem. The tube replacement it easy. Get to the back of the frig. Turn off the water supply. Carefully pry the white plastic piece out ( located on the upper right side when facing the back of the frig. ) of the frig. When you have the new one in hand it will be clear what you are going to do. Pull out the old remove the water line. Attach the line to the new tube and insert it. Turn on water, check for leaks, and you should be ok. This repair is only effective if you have an inlet tube that freezes up. There can be many other malfunctions that stop ice makers from working. This was my problem. Replaced the tube 3 years ago and ice maker has worked fine since the replacement.
Posted on Nov 24, 2008
SOURCE: Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Posted on Jul 13, 2010
SOURCE: MY JENN-AIR REFRIGERATOR #JCD2389GES IS
Possible that the vent is getting blocked to prevent the cool air to be blown into the fridge section. So make sure that the auto defrost is working, if not check the auto defrost timer section, the fan, the heaters.
make sure that the thermostat is set to normal.
Finally shut off the fridge for 6-8 hours and see if the cooling resumes. If so the defrost section must be revisited
Posted on Oct 30, 2010
Jun 20, 2014 | Jenn-Air JCD2389G Side by Side...
Feb 27, 2014 | Jenn-Air JCD2295KES Stainless Steel
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 14, 2010 | Jenn-Air JCD2389G Side by Side...
Jul 29, 2010 | Jenn-Air JCB2280HES Side by Side...
May 20, 2010 | Jenn-Air JCD2389G Side by Side...
Apr 08, 2010 | Jenn-Air JCB2388G Side by Side...
Sep 29, 2009 | Jenn-Air JCD2295HES Side by Side...
Jun 26, 2009 | Jenn-Air Refrigerators
Feb 10, 2009 | Jenn-Air JCD2389G Side by Side...
Dec 15, 2008 | Jenn-Air JSD2789GES Side by Side...
199 people viewed this question
