Question about Abit Computers & Internet
Panamatic midi sluice
Flashing f4
Posted by Varghese on
1helpful
My Kymco Midi mobility scooter won't move, and no green indicator fault level.
hi Alan, i have seen that fault before sadly the controller was faulty. No one by any chance remove the wiring on the controller and refitted ?
regards
Rob
Panamatic mini sluice flashing F6
Erlocip 100mg Buy Erlocip 100mg Online, uses, side effect, price
My CS 770 displays a flashing F4 Brother sewing machine
Perhaps this will help:
https://answers.yahoo.com/question/index?qid=20120713084921AAH7Vxl
Not much information on a Brother C4 error. You might try contacting Brother Support. Support Center
Code f4
need washer brand PLEASE! for f4 code. Good-Day!
Jun 23, 2014 • Dishwashers
Scooter, strider midi 4 was working 2 months ago but now when I push forward/reverse nothing happens
is there any bleeping or flashing light on the tiller ? is the freewheel lever disengaged correctly ?
Weird midi
A few things to try:
1) if your oxygen is connected using a midi cable instead of a usb cable it could be that the midi cable is damaged.
2) you may want to try changing the preset of your oxygen: use the buttons on the oxygen, near the two digits led, to selelct a program between 01 and 15, this will change the values assigned to the knobs
3) you may have some kind of midi loop going on, try going to the preferences in ableton and disable all midi controllers (remote, sync, track) both in and out; then enable only the oxygen for track IN and remote IN which is actually all that you need.
When i turn it on all it will say is "MIDI restore
The unit has lost the operating system and is in a BIOS type program waiting for you the send in the operating system file via MIDI. Download the file from the manufacturer and connect the unit via MIDI to do the transfer. The manufacture's site should have the directions. BE VERY careful as this is likely a "flashing" of the internal program memory and you don't want to lose power while doing a flashing.
The oven is set at 500 degrees. f4 is flashing and there is a beeping . we turned it off and then on again. it is still flashing f4 and beeping
check the wiring to the oven temp probe make sure there is no shorted or exposed wiring replaced parts as needed
Tascam midi and audio conflict error
First try turning off the onboard audio device using the BIOS interface. Try pressing f4, f2 or delete key rapidly at the flash screen beginning when you first turn on the computer. Look around in the bios (usually in "integrated periperals" area) and disable any onboard audio options that you see.
-In windows XP you can go to Control panel - Sound Devices and change the "map through" feature, select your default device, and run a hardware test simulation with a microphone for each device. Nice setup btw.
Computers & Internet Logo
Top Abit Computers & Internet Experts
Ekse
 TE5LA
TE5LA
Resolution IT Dubai
Resolution IT Dubai
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
