Dishwashers Logo
Question about Fisher Dishwashers
How do I test the lid closing on the dishwasher
Posted by Alex Le Roux on
W.L.
  • 2,511 Answers
Stop posting multiple questions which are the same
Posted on Jun 22, 2014
Dd603w wont close the last 1/4"
Greetings,
There are a few things that could keep it open..check to see if your lid is closing.. there are hoses and such that can cause this..Try and unplug it or turn off breaker and let sit 5 minutes..see if it works...Again, there could be problems with the lid closers..
Cannot unlock draw
Usually a locked draw is caused by an electronic controller failing.To open the draw you can pull it with even firm pressure but do not try and close it as thelid is in the "down "position.Before closing you must go inside chassis by pulling out the affected draw ,unclip the lid motors from the lid supports and push the lid up to the raised position and then wind the arms of the lid motors to the new height,manually and then clip the lid motor arms back into the lid supports.Then replace the draw.Then you must replace the electronic controller...
2answers
Top dishwasher drawer will not close
As long as there is no plates or anything stopping it from closeing i will then say that there are 2 side rails that the draw glides in & out on,get down on the floor & check up underneath the draw for smooth gliding operation.also is it possible that a fork or peice of cutlery has gotten over the top & fallen down jambing the draw from closing.
ERROR F5
F5 LED's o o @ o @
Lid actuator is jammed either up or down.
Primary Action
- Check for dishes preventing lid from closing.
- Check lid actuators in diagnostics.
- Check yokes are moving freely and are not jammed at the front or rear.
Secondary Action
- Replace lid actuators.
Tertiary Action
- Replace controller.
1helpful
Dishwasher lid stuck
the lids on dishdrawers are pulled down and sealed by lid activaters. there r two types, the screw type and the magnetic solonoid type. the reason your draw gets stuck is your lid activator is not releasing. there are 2 reasons for this 1st- 1 or both activators are faulty. 2nd the lid activator control board is faulty, which is located under the bottom drawer.pull the draw out and see if u can see if the lid is down on 1 side or both sides.please reply 4 more help.
AEG 250 operating manual
hi friend,
step 1
Remove any large food deposits from the dishes to prevent damaging the dishwasher.
  • Step 2 Load the upper rack of the dishwasher with smaller items, such as glasses, cups and cookware lids. The items must be inserted face down, with the soiled side of each item facing toward the bottom of the dishwasher. Some dishwasher models feature clips, which can be used to secure lightweight items to the tines of the upper rack. The clips work like clothesline pins, and can be moved from one tine to another.
  • Step 3 Load the lower rack of the dishwasher with heavier items, such as plates, bowls and pans. Insert the items between the tines of the rack with the soiled side of each item facing toward the center of the dishwasher.
  • Step 4 Load the silverware basket. The silverware should be inserted into the basket with some items facing up and some facing down to ensure the items do not fit together, which would prevent the dishwasher from being able to clean all surfaces. Knives should be inserted blade down, so they can be inserted and removed from the dishwasher with the handle to avoid injury.
  • Step 5 Add detergent to the dishwasher, and then close the dishwasher's door. Note that the dishwasher has two detergent sections. One dispenser, called the main wash section, has a lid. Open the main wash section's lid by pressing down on the cover latch located next to the section. Fill the main wash section with 3 tbsp. of automatic dishwasher powdered detergent, then close the lid until it snaps into place. The other detergent section is the prewash section. It does not have a lid, because the detergent within the section empties into the dishwasher when the door is closed. Fill the prewash section with 2 tbsp. of automatic dishwasher powdered detergent. Close the dishwasher's door until it clicks into place.
  • Step 6 Prime the dishwasher by turning the kitchen sink's faucet on until it produces hot water. This will ensure the dishwasher has an immediate supply of hot water.
  • Step 7 Start the dishwasher by choosing and pressing the appropriate wash-cycle button, located on the front of the dishwasher's door. Cycle selections include "POTS --N- PANS," "HEAVY" for heavily soiled items, "NORMAL" for standard washing, "CRYSTAL/CHINA" for delicate items, "LOW ENERGY" for lightly soiled items and "RINSE ONLY" for items that will not be washed immediately.
  • hope this helps u
    please rate me........................
    thank u for using fixya
    regards
    sivaranjini
    Bottom drawer of dishwasher is jammed and stiff..cannot close...as well soap dispenser is stiff...what to do
    The lid is pulling down by either left or right actuator causing the lid seal touching your tube. In running mode these 2 actuators pulling down the lid to seal the tube so no water leaking. When the cycle is completed, the actuators push the lid up. In this case one of them is bad not pushing the lid up. The actuators are not hard to replace. When you order, it comes with a pair, replace both. Inspect the lid, if the seal is damaged, you can order the lid to replace together.
    1helpful
    How do I test the lid motor on the bottom unit. The lid is not closing properly and triggers F1. I dried sensor and the upper unit is working.
    set for rince cycle start it and then pull gently if working properly the drawer wont move any slack change the lid motors
    1helpful
    Fisher & paykel top drawer stuck again
    Sounds like the lid is not opening all the way. Rubber may be coming off lid seal during opening and closing. Check you lid actuators replace both right and left if needed.
    Open Questions:
    Top Fisher Dishwashers Experts
    vince
    Paul
    NOEL
    NOEL
    Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
